Old 09-17-2018, 02:14 PM   #57
2017 16' Sport
Indian river , Michigan
Tow vehicle
Originally Posted by fishbisquit View Post
Thanks for the replies so far. We are in the process of searching for a new TV. We are zeroing in on a Ford F 150. We know it's over kill. But the design inside and out really appeal to us and there seems to be some really good deals right now. I've been trying to wade through all the WD or not for a small trailer threads but it really seems to come down to preference. I will need to get a hitch no matter what, so if I can get a used equalizer for $250 I think that makes sense. But I'm totally new to pulling anything over a 1000lbs.
My main concern is if the higher rated sway bars will add some undesirable performance to towing a lighter trailer?
I use f 150 xl w/2.7......totally impressed! Definitely not overkill! It sits in the sweet spot in regards to towing. I use weight distribution and double checked the dealer settings. 15k on trailer and personally would not use anything lighter as a tow vehicle. The bed doubles as a garage for all the goodies!
Kpope69211 is offline   Reply With Quote
Old 09-17-2018, 02:19 PM   #58
2017 16' Sport
I have a 16 sport (2016). I only wish I’d have purchased next size up engine wise.....I have a 26 on my radar but tw and towing will be at the high end of my 2.7.....my only regret
Old 09-17-2018, 02:21 PM   #59
2017 16' Sport
Towing
Expect 14 mpg @ 63 mph and 24 unhooked
Old 11-14-2018, 03:06 PM   #60
Hempel's Avatar
LaVista , Alaska
Does any one have a full sized Hensley hitch on a Bambi I’m looking at buying 19 Tommy Bahama and I found a deal on the Hensley Hitch. How well do they work on the smaller units.
Hempel is offline   Reply With Quote
Old 11-14-2018, 07:53 PM   #61
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i have a 22fb sport
as i talk before, I would not drive without
WD
sway bars
brake controller- Tekonsha Prodigy p3
rearview camera
as others have posted.
to take it to a trusted truck stop triple weigh scale once you feel the load is balance and ensure you have a book balance of weight
33% front, back and the trailer
ID:	327879   Click image for larger version
Name:	Tekonsha Prodigy p3-in Q5-b.jpg
waninae39 is online now   Reply With Quote
Old 11-14-2018, 10:37 PM   #62
On my unloaded sport 22 I was at @33% on both axles of TV and trailer, TV is 2018 f150 3.5 ecoboost. Towing on the ball with no WDH. I need to get my tongue weight up a smidge but it towed well empty and only @7% tongue weight.
Kanusport is offline   Reply With Quote
Old 11-15-2018, 06:18 AM   #63
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
Fredericksburg , Texas
Our 2015 Sport 22FB weighed 4040 lbs Loaded for travel with a full fresh water tank.
You should be weighing your set up with your trailer and truck fully loaded for travel including vehicle occupants, gear and a full tank of gas.
twbucksr is offline   Reply With Quote
Old 11-16-2018, 04:07 PM   #64
Hello,
My wife an I just purchased a new 2018 AS Sport 16rb. Very excited and have a million questions. First is the hitch. I'm pretty sure we are going to go with an Equalizer brand wd sway hitch. For the Sport the 600 tw / 6000 lbs version looks perfect. However there a few of the higher capacity hitches on the local used market. Some half the cost of the new 600 hitch. Would there be any issues with using a higher rated hitch on our 3500lb trailer? Any performance issues? Are there any concerns with using a used hitch?
Thanks!
If you get an f150 I wouldn’t get a WDH until you weighed it. I doubt you need a WDH for a 16 foot with an f150.
The WDH fan club may think so but real world numbers and ford engineers are what you should be going by. I’ve towed a 16 on vacation with my f150 and it towed fine. I also towed my new 22 on the ball and have CAT scale numbers to back up that no WDH is needed.
The WDH fan club is strong with their opinions but I’d try on the ball first.n
Old 11-16-2018, 04:31 PM   #65
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Eaz-Lift Sway Control
You may not need WD, but would be better off with some sway control. Many hitches like Equalizer have anti-sway as part of the WD setup, whereas others such as Eaz-Lift can be installed with only the friction sway control.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 11-17-2018, 10:04 AM   #66
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Congrats on your Bambi 176 purchase. I love mine and in New England it is a lot easier to get her in and out of tight places/campgrounds. I just have sway control on mine, usually tow with a full tank of water to put weight on the hitch. I towed pretty locally for a season with nothing but added a Husky sway control bar in preparation for longer hauls in sketchier situations. I loosen it/remove it when parking. I don't think you'd regret using an F-150 as a TV.
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 11-25-2018, 05:04 PM   #67
2017 22' Sport
Renton , Washington
Good Evening Bambi Forum,
I am towing a 2017 Bambi Sport 22fb with a 2015 Honda Pilot. It should be noted that I just moved up from a 2018 AS Basecamp that towed like a dream on a standard hitch.
Though I have the Blue Rhino WDH that the larger unit came with, I wanted to test the stability of the larger unit without the WDH. So I took the journey from Seattle to Portland and back this weekend sans WDH.
Initially I was going to test the WDH in one direction and the standard hitch in the other, but the ride down with the standard was so smooth and I was too lazy to engage in the additional set up required by the WDH when I broke camp in Portland.
Suffice is to say, I am absolutely certain I need to test the WDH on a future trip so as to have a decent comparison. However I am able to confirm a very stable and manageable ride back and forth between Seattle and Portland using a 2015 Honda Pilot AWD, going no more than 57 MPH towing a 2017 Bambi Sport 22fb in somewhat moist conditions.
I will keep you posted on the WDH test.
Glampman
Glampman is offline   Reply With Quote
Old 11-25-2018, 05:48 PM   #68
Awesome glampman, I too had similar results towing a 22fb on the ball only with an f150. It towed nice through the mountains too. It would be interesting to weigh your setup with each. I used a CAT scale at a truck stop and it was kinda fun.
Old 11-26-2018, 03:57 AM   #69
twbucksr's Avatar
2015 22' FB Sport
Overrated equalizer hitch on sport 16? Any issues?
Glampman,
FWIW, I towed my 2015 22FB for a year on just a ball hitch with my 2013 Honda Ridgeline and thought it pulled ok. Then I put an Andersen No Sway WD hitch on it and the ride and control was noticeably better. I’m sure you will notice a better ride with a properly installed WD hitch.
Kanusport is correct in recommending the use of a Cat scale to tune your set up. Make sure you are fully loaded with gas, water, gear and passengers when you do so.
Multiple passes thru the scale will probably be required as you adjust where you put your gear to get your set up level and weight safely below the payload of your Pilot and within the limits of both the AS and Pilot axles.
Safe travels.
Old 01-30-2019, 07:28 PM   #70
2019 22' Sport
High River , Alberta
Originally Posted by waninae39 View Post
i have a 22fb sport
WD
sway bars
rearview camera
I couldn’t tell from the photo. Are you using two friction sway controls? I can only see the RH unit mounted upside down.
I have a complete Eaz-lift setup (1000lb torsion bars) with two sway controls. I was planning to use only one of them with the new 22FB.
AlbertF is offline   Reply With Quote
ST-D rated tires vs ST-E rated tires Eagle & Bear Tires 6 11-15-2017 10:16 AM
equalizer hitch - any negatives? buffet breez Hitches, Couplers & Balls 126 02-10-2016 09:05 AM
Top Rated Sway Control Hitch (Hensley Hitch) Dgresham Airstream Classifieds 0 08-27-2014 10:20 AM
15 '' D rated verses 16'' E rated Tires hodges53 Tires 9 07-25-2014 07:16 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
