Old 07-20-2019, 07:42 PM   #1
2018 22' Sport
LittleCity , Colorado
Newbie Question about 22FB sport inverter
Hi, We are boondocking for the first time and ... our plug-in receptacles don’t seem to work ... and our microwave also is ‘dark’ ... we have a good (tested) battery and our lights, water pump, water heater all work ... but, we can’t plug in our toaster. So, are we only able to use the receptacles when connected to shore power?
El Juncal is offline   Reply With Quote
Old 07-20-2019, 07:53 PM   #2
TheSquire's Avatar
Lake Forest , California
This is normal. The 22FB doesn’t have an inverter unless you bought the upgrade. Even with the upgrade, you wouldn’t be able to run the microwave. The upgrade inverter only gives you AC power to a couple of outlets. The specific ones are in the wiring diagram in the users manual.
TheSquire is offline   Reply With Quote
Old 07-20-2019, 10:00 PM   #3
2018 22' Sport
Adding water via fresh water inlet
Hi, Thank you for resolving the non-working outlet mystery. One other question is ... at our campground, there is no way for us to hook up a hose to the fresh water inlet to fill the fresh water tank ... you have to fill a container and bring it to the trailer. We have a collapsible 5g container but, when we try to pour it into the fresh water inlet ... it doesn’t seem to go in very well. What is best practice for adding water via the fresh water inlet when you don’t have a hose hooked up to a water source?
Old 07-20-2019, 10:44 PM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we replaced the stock inverter with a victron 3k converter/ inverter. it works along with the solar and lion battery upgrade we did
waninae39 is offline   Reply With Quote
Old 07-20-2019, 11:37 PM   #5
2018 25' Flying Cloud
Portland , Oregon
I use a small transfer pump to get the water out of the container and into the trailer. Others have probably figured out some passive way to do it.
daleyocum is offline   Reply With Quote
Old 07-21-2019, 01:52 PM   #6
Napa , California
With the plugs, any that are shown as "inverter plugs" can usually handle up to 1000 watts for usage...so some chargers, low power hairdryers, low power coffee pots will work. But, stuff that requires more power will not.
And, for boondocking water invest in a few heavy duty rigid sided 4 or 5 gallon containers. They are strong, can be stacked, have a spout to use and are easy enough to handle for most folks. Invested in those after a trip where we struggled with a foldable container and were limited to the amount of water we could put in that thing...felt like we spend the entire week getting/toting/spilling water!
We usually carry 4 or 5 (if we have room). And of course the portable gray water tank to dispose of the used water.
https://smile.amazon.com/Reliance-Rh...s%2C197&sr=8-9
Atwebs is offline   Reply With Quote
Old 07-24-2019, 11:37 AM   #7
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
We just plan ahead and know where we will be. When we leave a full service hook up, we will put water into the internal water tank if we know we will boondocks on the next stop.
While boon docking we know our microwave will not work so we only plan meals that use the range or we use our portable Coleman dual fuel stove on the picnic table.
There is no way to get water to the onboard water tank unless you pack a 12vdc transfer pump. Keep in mind you will need an outside 12vdc tap to run it.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
Ham Radio Call sign K5FT
Msherw is offline   Reply With Quote
Old 07-24-2019, 11:50 AM   #8
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
For filling the tank, we carry a rigid jug. Ours did not come with a spout, just a spigot, but the spigot screws off, and a garden hose end fits the thread. So I also carry a cut-off piece of hose to do the job.
SSquared is offline   Reply With Quote
Old 07-25-2019, 09:27 AM   #9
Portland , Oregon
I just installed a 12v outlet inside the outside flip up door on the refrigerator. My transfer pump is a normal RV water pump but Harbor Freight sells them as well.
Old 07-27-2019, 04:07 PM   #10
2019 22' Sport
Tabernash , Colorado
Water help
We purchased this little item as a way to connect almost any spigot to a hose. We have been to several NPS campgrounds where there is not a threaded connection, and this solves for that problem.
https://www.amazon.com/dp/B01IBUP2RQ...eymoon_dp_vv_d
This is a LOLOHO link to the item.
JeffCross is offline   Reply With Quote
Old 07-27-2019, 04:47 PM   #11
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
I cut the bottom of a large soda bottle off at an angle and have used it to get water into the tank.
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 07-27-2019, 08:39 PM   #12
2016 22' Sport
Clinton , Montana
Here's the best solution:
Rpatrick16 is offline   Reply With Quote
Question? Replacing factory converter & inverter with 2k watt inverter charger cptdzl Batteries, Univolts, Converters & Inverters 1 06-23-2019 07:55 AM
Newbie Questions on my Sport 22FB - Batts, Solar Aerodmb 2005 and newer - Bambi all models 1 06-29-2018 01:53 PM
22FB Sport :: 2012 Airstream Sport Bonita Airstream Registry Discussions 0 03-29-2017 02:23 PM
Inverter - 2015 22FB Sport Frank&Mike 2005 and newer - Bambi all models 13 10-30-2016 10:46 PM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
