Old 02-26-2019, 11:43 AM   #1
Vancelot's Avatar
2018 22' Sport
Tyler , Texas
Need Wiring Diagram for 7 Blade Trailer Connector
Since I got my 2018 22FB, I have had trouble getting the trailer plug stay connected to my truck connector. I have to wrap a bungee cord to hold it in place. I know I could take it back to the dealership and have them replace it under warranty, but that is a 3 hour drive (partially through Dallas traffic) for a $8 part that I can replace myself.
This is the part I purchase and it fits snuggly into my truck's plug.
http://www.hopkinstowingsolutions.co...ade/48505.html
I comes with a wiring diagram, but says not to go by color but by function, because not everyone follows the same standard.
Does anyone know the correct wiring schema for the the connector on this trailer?
Vancelot is offline   Reply With Quote
Old 02-26-2019, 12:00 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Here you go
Dept of “OverKill”
Old 02-26-2019, 01:07 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
many people do not realize that the hinged cover has to go over and in font of the protruding tab on the TC connector.
That is what keeps it in.
be sure to push the connector in deep enough . the cover will then and only then keep the plug from coming out
waninae39 is offline   Reply With Quote
Old 02-26-2019, 04:42 PM   #4
Vancelot's Avatar
2018 22' Sport
Tyler , Texas
I understand how that works. This is not my first trailer. It would go in far enough for the tab to catch, but never far enough to make good contact. It's like there was a defect in the molding.
The new connector goes all the way in and fits snugly.
I will try the diagram posted by @GFML to wire up the new connector.
Old 02-27-2019, 09:11 AM   #5
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Vancelot....When you remove the old plug just write down what color wire you removed from what terminal on the plug and reassemble it the same same way and you should not have a problem.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 02-27-2019, 09:35 AM   #6
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Originally Posted by GMFL View Post
Here you go
I concur.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 02-27-2019, 11:34 AM   #7
2019 22' Sport
Cutler Bay , FL
what he said! ^^
eva52 is offline   Reply With Quote
Old 02-27-2019, 09:18 PM   #8
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
GM tow vehicles have the wiring diagram embossed on the socket cover. I use a wire tie loosely looped through one of the sockets ears. Through that I pass the breakaway lanyard before hooking it to the truck frame. Then if the socket falls out it does not get ground off dragging on the ground.
guskmg
Old 03-09-2019, 03:48 PM   #9
Vancelot's Avatar
2018 22' Sport
Tyler , Texas
Just now getting around to changing out this plug. There was no disassembling the old plug. It is injectection molded. I have the colors matching to the diagram above, except one, black. There are two thicker wires, black and white. Is black supposed to be the center wire?
Old 03-09-2019, 04:57 PM   #10
Vancelot's Avatar
2018 22' Sport
Tyler , Texas
I figured it out. Went through the Airstream owners manual and found the wiring diagram with wire colors labeled.
Here it is if anyone else wants to know:
Image taken from this link:
http://www.hopkinstowingsolutions.co...ring-codes.pdf
Trailer Connector - 7 Blade Spork Airstream Classifieds 0 04-20-2015 09:36 PM
7 Pin Round to 7 Blade Trailer Connector Adapter Needed Jeremy9107 Electrical - Systems, Generators, Batteries & Solar 14 07-25-2013 03:58 PM
wiring diagram connector qc1500 Lights - Interior & Exterior 2 12-29-2009 04:07 AM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
Connector Diagram at AIRSTREAM smily Brakes & Brake Controllers 0 09-10-2002 08:02 AM
