Old 03-22-2011, 06:59 PM   #1
2006 19' International CCD
Amelia , Ohio
Mystery Light
Well, we got our 19' Bambi Int'l home in one piece, and I've spent some time today looking her over a bit closer. Outside on the aft roadside, about halfway between the aft double windows and the cable/phone connections lies a somewhat rectangular, white-lensed light fixture that I can't figure out...the bulb tests good, but I can't detect any power to the socket despite having every switch I could find turned on. Does anyone know what this light is for, and how it's controlled?
Cheers,
Tom
jambie is offline   Reply With Quote
Old 03-22-2011, 07:04 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
If this is outside, it's a reversed polarity light for your shore power connection. This light, if it's what I think it is, is a danger--it provides a sneak path to power up the shell. If you step off the stairs onto wet ground while touching the shell, you will get a good shock (providing that the shore power socket is wired backwards, of course).
Zep
Old 03-22-2011, 07:17 PM   #3
Amelia , Ohio
Yep, it's outside. I edited my original post to reflect that. So it'll come on if the shore power connection is bad?
Old 03-22-2011, 07:24 PM   #4
blmitch5's Avatar
Olathe , Kansas
It must have been added by the po. I've got an 06 Bambi and no light over there except a small light by the dump valves. But it's under the belt line. Do you have a pic?
blmitch5 is offline   Reply With Quote
Old 03-22-2011, 07:27 PM   #5
Amelia , Ohio
I'll go take one and post it. It looks OEM, though...
Old 03-22-2011, 07:38 PM   #6
Amelia , Ohio
Here we go...
Old 03-22-2011, 07:45 PM   #7
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
It's a quasi porch lamp, 12 volts dc.
Colin
Colin H is offline   Reply With Quote
Old 03-22-2011, 07:45 PM   #8
reddogfox's Avatar
2008 20' Safari SE
Thumb Area , Michigan
Looks like a step light. Did you say it is on side opposite the door?
Richard from MI
20' 2008 Safari SE, Dill TPMS Silver Dog House
2007 GMC 1/2 ton Sierra ARE Cap
AIR # 10494
reddogfox is offline   Reply With Quote
Old 03-22-2011, 07:45 PM   #9
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Looks like our exterior step light and ours turns on with one of the rocker switches by the door.
Our light is seen in post #20, SilverGate's Safari is Home at Last! thread.
SilverGate is offline   Reply With Quote
Old 03-22-2011, 07:52 PM   #10
Amelia , Ohio
What I can't figure out is how to turn it on. If it's connected to the porch light switch by the door, then there's a problem in the wiring somewhere. Any more ideas?
Cheers,
Tom
Old 03-22-2011, 07:54 PM   #11
Amelia , Ohio
Yep, it's on the rear left side just forward of the red marker light.
Old 03-22-2011, 07:56 PM   #12
1975 31' Sovereign
1977 23' Safari
Now that's a reversed power light.
The photo of the light in question is definitely not a power light. The white light looks like a convenice light for hooking up at night.
Zep
Old 03-22-2011, 08:54 PM   #13
Bird's Nest's Avatar
2007 19' Bambi
2005 18' Westphalia
Evans , GA
We were recently told by a salesperson that an Airstream rep had told him that if they misfire a rivet or miscut a hole they will often cover it with a light or nameplate in lieu of replacing a panel. Maybe that's what happened with yours.
Bird's Nest is offline   Reply With Quote
Old 03-22-2011, 09:23 PM   #14
blmitch5's Avatar
Olathe , Kansas
Does the switch by the black and grey tank release turn it on?
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
2006 bambi, exterior, mystery
Tail Light Monitors? MDSilverado Lights - Interior & Exterior 3 10-19-2015 07:15 PM
How to Light the Pilot in the Oven lcurrie Stoves, Ovens & Microwaves 3 08-01-2011 07:16 PM
Right brake light outage, mystery solved. DaveFL General Motorhome Topics 1 02-21-2011 12:26 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
