Old 03-25-2011, 05:36 PM   #43
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Originally Posted by jambie View Post
Not quite sure I understand this. I can't get the light to work in the first place, so pulling fuses to determine which one turns the light off wouldn't work. Unless, of course, I'm missing something, which is entirely possible...
Cheers,
Tom
Ahhhchhhh ! Sorry Tom, I misread your post and had it in my head that you did have current to the socket.
You're right, my fuse pullin' idea ain't gonna do much good here.
This is an interesting one, keep us posted as to what you find.
Good Luck !
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 03-25-2011, 07:02 PM   #44
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Originally Posted by Bird's Nest View Post
We were recently told by a salesperson that an Airstream rep had told him that if they misfire a rivet or miscut a hole they will often cover it with a light or nameplate in lieu of replacing a panel. Maybe that's what happened with yours.
This sounds like the most likely explanation to me.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 05-10-2011, 06:47 PM   #45
Eliminator46's Avatar
1970 25' Tradewind
Cleveland , Texas
Images: 45
I have s 79 34' Avion with a similar light on the road side back by the service door. Inside the service door is an on off rocker switch that operates the light for mine. Have you looked inside the water hook up service door. I didn't notice in the thread that you have, but I may have missed it.
Eliminator46 is offline   Reply With Quote
Old 05-10-2011, 07:03 PM   #46
Has anyone with the same model/year been able to check the service manual diagrams to see if this item is listed in them? Possibly as an optional light?
Old 05-10-2011, 07:44 PM   #47
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
I have this exact same light on my 20'. It is turned on by the third switch from the right on the switches on the right as you enter the door. The same switch turns on a like light on the curb site. I think it is standard.
mhilley is offline   Reply With Quote
2006 bambi, exterior, mystery
Tail Light Monitors? MDSilverado Lights - Interior & Exterior 3 10-19-2015 07:15 PM
How to Light the Pilot in the Oven lcurrie Stoves, Ovens & Microwaves 3 08-01-2011 07:16 PM
Right brake light outage, mystery solved. DaveFL General Motorhome Topics 1 02-21-2011 12:26 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
