Correct. Remove the mattress and unscrew the six or eight screws. The board is actually two pieces that run the width of the trailer. While you have it open, its a good time to hard wire a fused
12V plug to the converter that can be mounted on the little ledge of your hamper (under the white lid at the foot of the bed). This will allow you to use a little cigarette lighter type inverter (mines 300 watts) to run your TV when your "boon docking" or use other
12V gadgets. If you decide to install the plug, you will want to make sure you can access the fuse without having to remove the mattress and bed boards.
https://www.amazon.com/BreaDeep-Univ...4BR2AP6DF6B80M
https://www.amazon.com/Scosche-0400A...GQV5FRVFYZHWH7
