12-22-2016, 06:58 PM
san jose
Mid 2000 Bambi Battery Monitor Accurate?
Hi all,
Anyone know if the mid 2000 year model Battery Monitor is accurate?
How is everyone ensuring they don't go below 50% on their batteries?
Thanks.
12-22-2016, 07:30 PM
Retired.
, At Large
A digital volt meter on a momentary contact switch will serve you well.
12-22-2016, 08:06 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
A 50% charge for wet cells and AGMs is generally reached when the resting voltage of the battery bank indicates 12.2 volts. "Resting" means no inputs from a charger (solar, generator or shore power) and no significant draws from lights, etc.. for about an hour. A voltage reading while charging or with a significant load is meaningless.
Bob Martel
WBCCI# 5766
12-23-2016, 11:26 AM
san jose
Thanks for the input. My solar is direct to batteries so if STORE is switched, no draw on batteries while Solar recharges.
I guess I'll have to add an easily accessible kill switch for panels so I can get a reading.
How accurate are the onboard battery meter on mid 2000 airstream 16's?
12-23-2016, 11:41 AM
Oswego
What Bob said, except some battery manufacturers charts differ slightly. Interstate says 50% state of charge for their "hybrid" LA batts is 12.06V. Since my monitor only reads to one decimal point, I use 12.1V as my bogey to recharge.
-Rich-
12-23-2016, 12:25 PM
san jose
Thanks.
Would be nice if my Solar controller had an OFF setting.
12-23-2016, 12:38 PM
Oswego
Originally Posted by vis0rd0wn
Thanks.
Easy to add:
http://rvsupplies.com/marinco-parkpo...rx_xoCaprw_wcB
Many similar marine cutoff switches out there. Shop for best price.
-Rich-
12-23-2016, 01:17 PM
san jose
Last question. In the evening in winter; there should be zero charge from the panels, so a voltmeter at the batteries should be accurate without manually switching the solar off with an inline switch correct?
12-23-2016, 01:34 PM
Oswego
Pretty accurate, provided no large draws within trailer systems.
-Rich-
12-23-2016, 03:51 PM
san jose
Thanks for the help. Never thought the onboard and solar charger meters would be pretty much worthless.
12-23-2016, 04:44 PM
2008 19' Bambi
Carlsbad
Check out the Trimetric battery monitor from Bogart Engineering. It keeps close tabs on your battery's state of charge, and shows current flow in or out of the battery as well as system voltage. It is a neato gizmo.
Russ
12-24-2016, 11:41 AM
2011 30' Flying Cloud
Arvada
I've never found the installed systems monitor to be totally accurate, so I agree with Overlander that a digital volt meter would serve you well.
