Old 03-16-2019, 06:10 AM   #1
Sheridan , California
Loose Screw
I have a mini blind bracket screw that will not tighten into the interior aluminum skin. Must not be anything structural behind the skin.
Any suggestions on how to reduce the size of the hole so that the screw will grip a little better?
I have used JB weld before, with some success, to make a hole smaller.
Airabel is offline   Reply With Quote
Old 03-16-2019, 06:26 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
There is nothing behind the skin. You'll need to use a larger screw, and don't overtighten it.
Old 03-16-2019, 07:33 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
If you can't pull it out with your fingers...I have used 3m 5200 on the accordion blind mount, it has to cure completely, no stress for 7 days. Coat the threads well and wipe all the excess...worth a try. 👍
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-16-2019, 07:55 AM   #4
2018 23' Flying Cloud
Savoy , Texas
Check out the Hillman group short Jack nut. It works like a pop rivet but has machine screw threads.
SpinWhite is offline   Reply With Quote
Old 03-16-2019, 08:12 AM   #5
1994 30' Excella
Mississauga , Ontario
I think another option would be a riv nut.
Al
Al and Jean
TAC ON-3
Old 03-16-2019, 08:56 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I think a jack nut would be overkill- and require a relatively big hole. A pop rivet or a bigger screw is what I'd use.
2012 Dodge Durango Hemi/AWD
Old 03-16-2019, 10:13 AM   #7
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
There are no Airstreamers without a screw loose.
Alumacoot
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 03-17-2019, 07:45 AM   #8
Looks like the 3m product is about the same as JB Weld. Curing time is a little less. When I removed the mini blind 2 of the 4 screws were loose so filled the holes with JB.
Had the gas heat on while working on the blinds. While working over the sink, accidently, unknowingly, hit the waterheater on - off switch. Did not discover it for several hours when I was outside the trailer and heard it come on then off. Now I'm worried about screwing up the waterheater. Guess I'll find that one out later. Still winter here.
Old 03-17-2019, 07:59 AM   #9
3m 5200 Marine stays pliable, if you need a permanent bond use 5200 slow cure, fast cure if it has to come apart, both are very strong.
Pliable may work better shaky unstable applications.😂
Amanamus
"Tahawus"
Exterior Trim, Did a Rivet or Screw come loose? OSCS General Repair Forum 3 09-17-2017 08:07 AM
HERH Operator Screw Trailer Girl Roof Vents, Skylights & Fans 11 06-09-2005 07:33 PM
Retainer Screw on running light? stevepdx Lights - Interior & Exterior 1 02-05-2005 03:43 AM
Screw holes in my skin 58BUBBLE Ribs, Skins & Rivets 11 09-12-2004 09:53 PM
Screw coming thru vinyl cynthia Floor Finishes 19 08-26-2004 05:00 PM
