Old 05-30-2012, 09:58 PM   #15
netman1969's Avatar
2006 19' International CCD
Leesburg , Virginia
Yamaha Gen
I just wanted to add that we just purchased our first travel trailer. It is a 2006 19' Bambi 75th Anniv. CCD. With the purchase we got a Yamaha EF2400. Now we haven't had the opportunity to use it yet, but the previous owner said that it runs the AC just fine with the lights on that everything else on Propane. What I can tell you is that the generator hadn't been run in almost 3 years. I gassed it up and it started on the 2nd pull. Very smooth and quiet. I cant wait to run the trailer on it, but I do want to get a larger gas tank. In fact, I have been thinking about how to hook it up to the truck gas tank. Anyone ever done that or have any thoughts on it?
Smitty
netman1969 is offline   Reply With Quote
Old 05-30-2012, 10:17 PM   #16
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
I know I'm gonna take some heat from all you Honda and Yamaha guys. I bought two Champion 2000 inverter gensets at Costco and ordered the sine connector with the 30amp plug. They stack nice, run well are quiet and will run everything on the AS. Time will tell about reliability. Champion seems to want to make a presence in the US market and their products have gotten good ratings. I hope it was a good choice. They sure look nicer stacked together than the other ones.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 05-30-2012, 10:19 PM   #17
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Smitty
2 potential issues with running the generator directly from the truck's fuel tank.
One is that modern fuel systems are very particular about pressure and venting in the system, and it doesn't have to be far off what the computer expects to cause it to flag it as a problem and light the "Check Engine" light, and potentially cause you to fail an inspection if emissions is part of your local vehicle inspection regiment.
Another is that you must be careful to pull fuel from significantly higher than the tow vehicle's fuel pickup, so that you don't accidentally run the fuel too low.
— David
Old 05-31-2012, 08:53 PM   #18
netman1969's Avatar
Leesburg , Virginia
Thanks DKB, I very much appreciate the advice. We have an 06 4-Runner with a 23 gallon tank and rarely let it fall below a quarter of a tank. My thought was that if we fill up on the way in to camp (or close), that gives us a good supply of gas if we are boondocking. I seriously doubt we would need to do this often at all, we expect to camp at established grounds more often. But, it may be an option. As far as I can tell, there are no screens or filters between the fill and the tank, but naturally I will verify that first.
Smitty
Old 05-31-2012, 10:51 PM   #19
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Welcome to the Forums! And congrats on your new Bambi and your new generator... You're all set then! Let the fun begin!
(We have a 13,500 BTU AC so we use two Honda 2000s when we want AC and one other times... Space is a premium for us so it's nice to have the smaller footprint than the 3000w when we need only one...not to mention more manageable weight ...for us.)
TB & Greg and Abbey Schnauzer
#3954
Old 06-01-2012, 04:23 AM   #20
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
DW loves the power but hated the gas smell, so I converted to dual use LPG four Seasons ago. LPG gets used anytime we're camping, the small tank lasts close to a week with careful use.
Name:	PROPANE CONVERSION, HONDA 2000 001.jpg
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 06-01-2012, 12:16 PM   #21
2000 25' Excella
Northern , California
This thread has gestated for a while, and many users have offered sage counsel on various generator options, so I hope I'm not hijacking it by offering my perspective.
The generator question seems to pop up a lot, and many users have articulated their very legitimate sizing requirements to meet their needs, such as 2000w or so in order to power most microwaves, 3000w or the combo of 2-2000w to power most AS AC units, etc. Some users with more limited needs, express an interest in powering only a few lights, and charging their batteries to extend their dry camping. They’ve asked about the 1000w generator to meet those needs.
My view is that the 1000w generator will easily power the lighting, and will charge the batteries, especially if you remove them and connect the generator directly to a quality external charger. Besides that, the 1000w has significant limitations, that aren’t justified in the small pricing differential between the 1000w and the 2000w sold by Honda and Yamaha. Consequently, my view is that if one is buying either of those quality brands, then I would spend the extra couple of hundred bucks and buy the 2000w over the 1000w, even if your current needs can be met with only the 1000w unit.
On the other hand…I think there’s another, far cheaper option for those with very basic lighting and battery-charging needs. I realize that there’s a love-hate view of Harbor Freight products on the forum, but I’ve found that while many of their products may not meet heavy-user professional needs, they economically and satisfactorily meet many typical homeowner needs, which often only get occasional use. If I were shopping for a 1000w generator to meet those very basic needs, then I would take a look at this 800w HF unit, currently sell for $99 (with Super Coupon). On the surface, my only aversion is 2-cycle, but for $99, limited power requirements, occasional needs, you’ve got very little value at risk versus the $800 or so for the 1000w better-known brands. If it doesn’t work out, save it for the home emergency, or take it to a recycler.
Maybe some other forum users already have experience with this product that they could share, pro or con.
Name:	HF 800w Generator.jpg
Kamiak is offline   Reply With Quote
Old 06-01-2012, 12:28 PM   #22
dznf0g's Avatar
Oswego , Illinois
The blue unit above is sold under MANY names and with a few configurations. I just couldn't pass up this chinese unit at a local store for $99 badged as a Coleman and green in color. Mine must be the "deluxe" unit as it has a volt meter, a 12V outlet and a couple other items.
It's a 2 stroke and quite loud. I'd never use it in a campground, but it's fine for toting to a worksite to power a saw, drill, etc. Runs well and actually will pull 1200 watts at 118 volts. Parts? uh, it's a throwaway.
I'll also say, if you are boondocking with no neighbors and you can stand the noise, it is plenty to charge the batts through the converter (pulls 900W max and tapers off). After say 15 minutes the converter drops to pulling about 400 watts, then you can watch TV, use lights, etc.
-Rich-
Old 01-21-2013, 08:51 PM   #23
I do have one caveat about the pictured $99 generator. It is based off a 1970s Yamaha design, the ET800. It was never designed to run electronics or anything sensitive to voltage surges/spikes/transients. Some YouTube videos will see 160 volt spikes when turning on and off loads.
With the economy as shabby as it is, if that generator is all one can afford, then that is it, and there is no shame in having one. However, if this is going to be someone's "main" generator and one could afford more, I'd at least buy a Champion open-framed model that is a four stroke, or even better, an inverter generator which would give clean power. Of course, the ideal is a Honda or Yamaha, but they are pricy but well worth it.
The uses I can see for the ET800 clones is either something to have in case of emergency (and its carb is delicate, so it will need to be run completely out of fuel and the float bowl drained before storing, or it would need to be stored fuel that has both the oil and Sta-Bil in it), or powering something that can handle the dirty power, such as incandescent light bulbs, pumps, or the like.
Kamiak is right about 1000/2000 watt inverter generators. The price difference is so low, (oftentimes just a C-note) that unless the weight or space is a major concern, just get the 2000 watt model. This will handle most loads except for a larger microwave, or a 13,500/15000 watt AC.
mlts22 is offline   Reply With Quote
2006 bambi
Any Generators? Boytoysoh Electrical - Systems, Generators, Batteries & Solar 8 09-22-2008 09:35 PM
Generators.... rmanalang Generators & Solar Power 7 01-23-2006 10:27 AM
generators simzeez 1970 - 1973 Sovereign 3 04-30-2005 10:08 AM
Generators PeterH-Airstreamer Airstream Motorhome Forums 25 09-07-2004 09:46 AM
Generators csimingt 1999 Safari 11 07-26-2004 08:38 PM
