Old 09-04-2018, 09:08 PM   #101
2017 22' Sport
Portland , OR
Half of Dexcom #11 lift kit for sale
FOR SALE: 1/2 of Dexter #11 dual axle lift kit. Shipped to you anywhere in the US for $95. Send me a message if interested.
Installed the other half of the kit on my 2018 22FB Sport and love the results.
As others notes, my copper propane line ran through the existing axle bracket. The pipe must have been inserted through the axle bracket before the pipe ends were flared, as it did not fit back out. Since I didn't have a replacement propane line on hand, I just bent the copper pipe down to the new axle position. It's not ideal having the propane line hanging down a few inches from the under-body, but it also seems highly unlikely that it will get snagged on something.
Name:	Dexter #11 Lift Kit.jpg
ID:	321537   Click image for larger version
Name:	Propane line through axle.jpg
wackywander is offline   Reply With Quote
Old 09-05-2018, 09:01 AM   #102
gcstreamer's Avatar
forked river , Arizona
Hey wackywander. I'm new to forum . But I'll take the other half of the lift kit . I have a 2019 sport 22. I've read this whole thread and I want to lift mine. I'm in NJ. Does paypal work for you ?
gcstreamer is offline   Reply With Quote
Old 09-06-2018, 01:44 PM   #103
2017 22' Sport
Portland , OR
Update: sold lift kit to gcstreamer.
Old 09-06-2018, 05:28 PM   #104
Boxite's Avatar
2008 22' Safari
I recommend you insulate that copper pipe from chafeing where it contacts your axle supports with some rubber hose or foam pipe insulation and tye-wraps.
Old 09-07-2018, 02:30 PM   #105
2017 22' Sport
Portland , OR
Thank you Boxite for the great suggestion-- I'll wrap the pipe this weekend.
Old 09-07-2018, 02:47 PM   #106
2007 22' International CCD
Or, to make it easier to install,get some corrugated 'split loom' from the auto parts store.
Measure the copper first to see what inside diameter (I.D.) split loom you might need. I'd bet a minimum of 1/2 inch split loom.
It looks like corrugated tubing, and has been slit lengthwise so you can easily put it over the pipe by just sliding it on once you get it started. Handy stuff for protecting exposed wiring also.
Slip it on, and secure it with a few black nylon tie-wraps or spot wraps of quality black electrical tape at 1-2 foot intervals and at the ends of the run.
I must admit that it just blows me away that the factory thinks it makes sense to run a propane line like that. I'm sure I'll be cussing them roundly when I put a lift kit on mine...
Old 09-19-2018, 04:43 PM   #107
1977 Argosy Minuet 6.0 Metre
Pittsburgh , Pennsylvania
Does anyone know what is the original clearance on the 22' Sport, before doing the lift? I've tried to find that spec, but not turning up anything other than "too low"...
Looking at possibly doing the same thing on my Argosy. From the old manual, I have the info: Ground clearance ... 16" to underbelly, 12" to axle tube.
I know my axle is shot, but at least I know where it supposedly started... so equivalent info for the Sport would be great.
Thanks for any info y'all have!
MrSalt is offline   Reply With Quote
Old 09-19-2018, 05:46 PM   #108
... just to clarify, that's the info for my Argosy, still looking for the clearance on the Sport!
Old 09-20-2018, 07:03 AM   #109
2018 22' Sport
Durham , North Carolina
I am adding a photo of the clearance of my 2018 Sport 22FB before adding the lift kit. It shows only 8 inches of clearance from the lowest point: the skid protecting the drain.
Name:	Sport 22FB clearance.jpg
LContinental is offline   Reply With Quote
Old 09-20-2018, 08:41 AM   #110
2017 22' Sport
Portland , OR
I just went out and measured clearances on my 22 sport, after the 3" lift. This is with the unit pretty much at capacity as far as load (full of gear and full water tank):
10 7/8" to axle (unchanged by lift kit)
18" to underbody (15" before lift kit)
11" low point in front, spare tire holder (8" before lift kit)
10.5" low point in back, sewer drain (7.5" before lift kit)
Old 09-20-2018, 10:26 AM   #111
Boxite's Avatar
2008 22' Safari
The lowest point of concern for me was the sewer drain which was 7-1/2" before and almost 11" after.
Old 09-20-2018, 10:04 PM   #112
Thanks, LContinental, wackywander, and Boxite!!
That's exactly the info I needed. I can measure things next week on the Argosy, and have a much better educated guess... most likely it's a go.
Old 09-22-2018, 10:35 PM   #113
2017 22' Sport
Calgary , -
Anyone else have half a kit to sell for the 22FB?
robinjen is offline   Reply With Quote
Old 09-24-2018, 12:59 PM   #114
Boone's Avatar
2015 22' FB Sport
Ranchos de Taos , New Mexico
Hello, we have one. We paid $90 locally in anticipation of purchasing a 22FB. It turns out the 22FB already had the lift installed. I will sell for $90 plus shipping.
Boone is offline   Reply With Quote
Old 09-24-2018, 06:10 PM   #115
2017 22' Sport
Calgary , -
I'll take it, will message you
Old 10-02-2018, 12:01 PM   #116
MIAMI , Florida
I also have 1/2 of Dexter #11 dual axle lift kit available. K71-724-02.
Other half went on my 2016 22FB
$95 Shipped
ID:	324283   Click image for larger version
jonahmiami is offline   Reply With Quote
Old 10-07-2018, 05:27 PM   #117
2017 22' Sport
AUSTIN , Texas
Is the other half still available?
Pfchang is offline   Reply With Quote
Old 10-07-2018, 05:50 PM   #118
MIAMI , Florida
Sold
Originally Posted by jonahmiami View Post
i also have 1/2 of dexter #11 dual axle lift kit available. K71-724-02.
Other half went on my 2016 22fb
$95 shipped
Old 10-09-2018, 03:20 PM   #119
2017 22' Sport
AUSTIN , Texas
Just ordered a kit.
If anyone is interested in buying the other half feel free to PM me.
Old 10-27-2018, 08:44 AM   #120
MCJ
MCJ's Avatar
2019 22' Sport
San Francisco , California
I also bought a new kit (dexter #11 dual axle K71-724-02) for my 2019 22FB and happy to sell the other half for $95, includes shipping.
MCJ is offline   Reply With Quote
