Old 10-11-2014, 02:54 PM   #1
Leveling jacks
I bent the two front jacks and I am wondering if the scisor jacks would be better than the original jacks?
BillbB is offline   Reply With Quote
Old 10-11-2014, 02:56 PM   #2
Gainesville , Florida
Stabilizing jacks, not leveling jacks. Is that how you bent them. Scissors jacks would just be used for stabilizing the trailer. Jim
Old 10-11-2014, 02:57 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, I do not think it matters which style you use. As long as you do not try to use them for actually leveling the trailers, stabilizing yes, but not designed for lifting/leveling.
You beat me too it Jim.
MICHAEL
Old 10-11-2014, 03:06 PM   #4
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Crank 'em down til they touch the ground, then a bit more til the trailer jumps a tiny bit.
I use a cordless drill with a 9/16" socket bit. When the drill starts to twist out of my weak old hand, that's enough.
terryV is offline   Reply With Quote
Old 10-11-2014, 03:50 PM   #5
1977 Argosy 24
Milltown , Wisconsin
The original "BAL" jacks fold up closer to the bottom of the trailer. The scissors jacks hang down more, so less ground clearance. I bought 4 new BAL jacks for my Argosy when I got it, as it had none from the factory. I also think the scissors jacks look ugly hanging down under the trailer. Just my opinion though.
ventport is offline   Reply With Quote
Old 10-12-2014, 03:54 PM   #6
2007 19' Safari SE
Los Gatos , California
Leveling system
To level my Bambi, I bought a nifty leveling wedge. I've used it several times and it's as easy as this video makes it look.
Rye
RyeL is offline   Reply With Quote
Old 10-12-2014, 06:09 PM   #7
2008 27' Safari FB SE
Akins , Oklahoma
Images: 20
If you bent the jacks you probably bent the frame cross members as well or stripped some of the threads out of the inboard mounting holes. The metal there is not very thick.
sequoyah101 is offline   Reply With Quote
Old 10-12-2014, 10:53 PM   #8
Bellevue , Washington
I bought the BAL. Tried once, works nice. Just one drawback, seems storing it costs some space. Bambi16 is too small.
shockfly is offline   Reply With Quote
'97 Safari 25' Leveling jacks 25Safari_97 Jacks, Stabilizers, Lifting and Leveling 3 07-12-2009 03:59 PM
**Leveling Jacks** Silvertwinky General Motorhome Topics 31 05-16-2008 04:53 PM
steps/leveling jacks??? swinginping Classic Motorhomes 4 03-11-2008 06:21 AM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
Cable/sat hookup/leveling jacks Ga Pockets 1984-1988 Limited 10 01-14-2005 02:08 PM
