Old 12-05-2015, 09:24 AM   #1
Cazenovia , New York
Ladders-telescoping?
We are considering getting a telescoping ladder for our Sport 22' that we tow with a Ford Flex...no space to store extra stuff, so considering a telescoping aluminum ladder. Any suggestions?
rlewis is offline   Reply With Quote
Old 12-05-2015, 09:33 AM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I carry one of these (Professional Heavy Duty 8.5 ft Aluminum Extension Telescopic Contractor Ladder).
Doesn't get used much, but works great when it does get used (330lb rating), unfortunately not always in stock with Amazon.
martin300662 is online now   Reply With Quote
Old 12-05-2015, 09:41 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Have had one of these since the AS was new.(early version)
Store it in the case....BUT it is a pretty substantial piece...25lbs & bulky, it will fit in the Classic's 'trunk' though.
IMHO.... ladders, buy quality.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 12-05-2015, 10:25 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
I've been using the Telesteps every day for over a year. They make several models. For an Airstream trailer, the smaller regular model works very well.
I use the 16' Pro model. The best feature is the single button that allows for the quick retract of all the rings.
Expensive but well worth it.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 12-05-2015, 10:35 AM   #5
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
I have a telescopic ladder that I got off of eBay. After some research discovered that the one I got is the same manufacturer as they sell at Camping World for half the price. (Just re-branded). Couple of things you must keep in mind when using one. Make sure your sections are full secured when you pull it up, and make sure your fingers are clear when you are letting it down! Sucker gets heavy near the end and can smash a thumb good! (experience speaking).
Here is a question that will probably be relevant for the OP. I haven't ever used mine to access the top of the trailer because I don't want to dent panels. Is there anyplace where you can buy some sort of ladder guard that would distribute the weight on the ladder enough as to not bend or dent the aluminum?
D
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Old 12-05-2015, 11:16 AM   #6
2016 30' Classic
Maitland , Florida
So what do you do with these ladders? Lean them against the Airstream?
FreshAirStmr is offline   Reply With Quote
Old 12-05-2015, 11:43 AM   #7
lewster's Avatar
If you lean them against anything, you need a pad on the top to prevent scratching or worse, especially on the fragile surface of an Airstream.
I have special foam caps made for this purpose. I'll post a photo when I get back to a computer later today.
Lew Farber
541-490-6357
Old 12-05-2015, 02:17 PM   #8
Keen amature
1975 20' Argosy 20
Chestfield , Kent
As in 'what do you use them for?'
We have a rope and pole awning and the awning channel is approx approx 7ft 6in off the ground; a ladder makes it much easier to run the awning into the channel.
Old 12-05-2015, 02:19 PM   #9
dznf0g's Avatar
Oswego , Illinois
Tilt solar panels, fix any number of multiple problems on the roof
-Rich-
Old 12-05-2015, 03:07 PM   #10
2016 30' Classic
Maitland , Florida
Sorry, I didn't really mean "what for," but rather "how to use." It seems like you could dent the Airstream when leaning a ladder against it but I really don't know. We've only been in possession of ours for 5 days. Scratching can be prevented, as Lew mentions, but are dents possible?
Old 12-05-2015, 03:28 PM   #11
dznf0g's Avatar
Oswego , Illinois
I only lean it on the metal awning roll. Or maybe a window brow, but only as a last resort. Never on the skin
-Rich-
Old 12-07-2015, 02:04 PM   #12
lewster's Avatar
A few shots of how I do it:
The cap is made in the USA using different densities of foam, with a very hard but pliable foam side that goes agains the coach wall. 'Been using these for about 18 months now…….very effective and not a scratch or dent to be found in any Airstream side wall...
Old 12-07-2015, 02:51 PM   #13
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
Although we won't take possession of our '25 Flying Cloud until Febuary, I have been pondering the ladder problem. I was really looking for a ladder that took up the least amount of space and was only considering it for pulling unlatching and pulling down the awnings, hoping I never have to climb on the roof while on the road.
This one is very compact and collapses to 3.5"x4.5"x64" and looks very attractive. I'm just waiting for delivery of the trailer to see which one is stow-able in one of the outside compartments.
Folding Ladders & Step Ladders, Best Folding Ladder | Folding Ladder System | ladder-guy.com
abqdor is offline   Reply With Quote
Old 12-08-2015, 09:02 AM   #14
Lew,
Where did you buy your ladder cap?
pattonsr is offline   Reply With Quote
Ladders on a classic morlach Classic Motorhomes 17 09-05-2014 05:05 PM
Telescoping ladder - Werner 11 footer JBinKC General Repair Forum 20 12-29-2010 03:50 PM
Telescoping Table Pedestal source? mrsfixit Cabinets, Counter Tops & Furnishings 2 12-25-2010 11:30 AM
Telescoping trailer tow mirrors - must have? cbgenrich Tow Vehicles 12 02-24-2009 11:34 AM
Extend Ladders Davydd Our Community 3 02-15-2004 12:16 PM
