Old 03-16-2015, 01:38 PM   #1
2004 19' Bambi
Santa Barbara , California
Jacking up Left Rear Tire on '04 Bambi 19'
Hi,
I'm trying to jack up the left rear tire and I am having a difficult finding a jack spot underneath near the axel. In my manuel, section C-5 (I think) it shows a picture indicating the 'jack point' is between the rear stabilizer and the tire. Only problem is that's the sewer side. Nothing but solid smooth surface underneath except for a small bend out piece of metal. I tried this point with a 2x4 on top to distribute the weight--the ball joint ? to the tire interfered for a good fit.
I need to know where to put my small hydraulic jack underneath my 2004 Safari Bambi, left side tire. If you've jacked up your outfit before, give me a shout and tell me how you did it.
Rick
SBAir
sbair is offline   Reply With Quote
Old 03-16-2015, 02:14 PM   #2
1999 28' Excella
New Orleans , Louisiana
After getting an axle bent from someone jacking in the wrong spot we use the plastic ramp exclusively even at tire shops. I have to drive it on and they do not mine. The ramp is inexpensive and we have a 28' that weighs 8200 lbs. Works like a charm.
badkat is offline   Reply With Quote
Old 03-16-2015, 02:17 PM   #3
2007 22' International CCD
Only works on a dual axle trailer. Bambi typically only has one axle..,,
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 03-16-2015, 03:12 PM   #4
2004 19' Bambi
I found the spot to jack up 19' Bambi ('04) on the left. I couldn't see it just looking under the trailer, on your back, crawl under and you will see a sticker saying Jack with arrow. From that sticker location, look for a row of rivet heads from the rear of the trailer towards the front of the trailer in a 'straight' line. This is where the frame is and that is where you put the jack. I used a 6" 2x4 on top of my 2 1/2 ton barrel hydraulic jack and it worked fine.
Left turn and left brake lights not working Morgan guy Lights - Interior & Exterior 9 02-01-2015 07:08 AM
Jacking point for flat tire 31' Sovereign rozwd 1974 - 1979 Sovereign 6 04-07-2013 06:53 AM
Rear Twin beds--left with extra boards dcasr General Repair Forum 3 12-24-2010 07:43 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
Jacking a 1962 safari for tire changes Rubyacht Tires 3 01-14-2004 10:42 PM
