Old 06-06-2014, 05:29 AM   #1
AvidTraveler's Avatar
2014 16' Sport
Bradenton , Florida
Interior LED Lights?
For those that have changed out interior lights for LED's, where's a good place to get them? Is it a simple swap-out, remove old ones & put in new ones, or is there more to it than that? (Just got a 2014 Sport 16.)
Thanks!
Irene
AvidTraveler is offline   Reply With Quote
Old 06-06-2014, 05:49 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
I bought LED bulbs on EBay. Simple swap out.
BambiTex is offline   Reply With Quote
Old 06-06-2014, 05:54 AM   #3
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
For the halogens in the ceiling lights, I ordered my LED's from Airstream, but for the under cabinet lighting, bath area, and closet, I ordered the complete fixtures (look exactly like the factory installed) from Amazon. Also replaced the step light. Lat thing to change is the light in the rear access storage area. Hugh energy saving since we boondock and get power from solar.
tsunami is offline   Reply With Quote
Old 06-06-2014, 09:48 AM   #4
dznf0g's Avatar
Oswego , Illinois
This is my go-to site. They specilize in many AS lighting products. Customer service is great:
http://led4rv.com/index.php?main_pag...60tdtuo9thmii0
This one I use for unique stuff where I am looking for something LED4RV doesn't have:
Installation/Power Supplies/Misc | Super Bright LEDs
-Rich-
Old 06-06-2014, 07:12 PM   #5
'15 Flying Loud 20' Bambi
renderit's Avatar
2014 16' Sport
small city outside a big one , south of some, north of some
I got them very cheaply on Amazon. Be careful to get the soft white kind or you probably wont like them. I just replace all bulbs, not fixtures. And those outside already have LEDs in them. I think there are 13...
renderit is offline   Reply With Quote
Old 06-06-2014, 07:21 PM   #6
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I got mine from Airstream, lady very nice walking me thru. Swap hard up inside the cabinets, even with trifocals and bending around backwards with my left handedness, those little prongs were tough to get in sometimes and very delicate.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 06-06-2014, 07:52 PM   #7
aftermath's Avatar
Spokane , Washington
I thought the 2014 coaches all came with LEDs. Am I missing something?
aftermath is offline   Reply With Quote
Old 06-06-2014, 07:56 PM   #8
1974 Argosy 20
Kooskia , Idaho
The FC's sure do, maybe the sport is still using halogen?
Old 06-07-2014, 03:07 AM   #9
renderit's Avatar
2014 16' Sport
The Sport (16 at least) uses the bayonet style push and twist 12 volt regular bulbs inside. Easy to find and replace, no hunting for tiny holes.
Old 11-23-2016, 07:32 PM   #10
2007 19' Bambi
I would also check the color temp of the new LEDs. I found using 3700 to 4000 K for general lighting and 5000 k for task lighting worked well for me!
bcroome is offline   Reply With Quote
Old 11-24-2016, 11:15 AM   #11
2016 19' Flying Cloud
Miami Springs , Florida
A bit off topic, but since you bring this subject....
We have 2016 FC 19 and it allready comes with LED, but the light is so bright and white that it feels like a hospital. Can those be changed to something warmer?
Gallego is offline   Reply With Quote
Old 02-26-2017, 11:56 AM   #12
2017 22' Sport
edison , New Jersey
Looking to replace my led lights on my 22fb. I took the housing apart and found everything soldered. They dont make it easy to replace. Do these leds not blow out?
2017 Ford Expedition EL
2017 Airstream 22FB Bambi
redvfr02 is offline   Reply With Quote
Old 02-27-2017, 07:11 AM   #13
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
Fredericksburg , Texas
First mod I attempted and completed on my 2015 22FB was switching out the factory installed incandescent heaters for LED's. I replaced them with a combination of warm and bright LED bulbs throughout. I just popped the lenses off the fixtures, pushed in the bulbs and turned. Out they came.
twbucksr is offline   Reply With Quote
Old 03-05-2017, 04:37 PM   #14
Boxite's Avatar
2008 22' Sport
Why do you want to replace them?... and WHICH lamps are you replacing? (Outside running-lights? Interior dome lights?)
Your last sentence indicates they are not "out"... so,... again, why do you want to replace them. They last practically forever.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
LED lighting retrofit for interior lights Westfalia Lights - Interior & Exterior 372 12-17-2016 11:43 AM
LED Lamps for interior lights drboyd Electrical - Systems, Generators, Batteries & Solar 56 06-05-2011 10:06 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
