Old 03-01-2019, 05:46 PM   #1
Boise , Idaho
In a dilemma between 16' and 22'
Well just as I thought I had decided on the 2019 Sport 16' I have a friend let me know that he is in need of money and would be willing to sell me his 2017 sport 22' for about 5k cheaper than what the newer 16' would cost me. And his price is about 7k less than what I have been seeing the 22' go for online.
I only need something to sleep in and cook during weekends, I will not be living in it. Is passing up this offer a bad idea? If only I could try them both out, but thats obviously not an option.
James3344 is offline   Reply With Quote
Old 03-01-2019, 06:06 PM   #2
2017 23' International
hendersonville , North Carolina
16 vs 22
No brainer. Get the 22' providing you have qualified tow vehicle. The sport 22 is a slightly smaller version of the popular 23FB model. Again, take the deal on the 22. You will be glad you did. Just the bathroom in the 22' should be reason enough. Happy travels.
uraljohn is offline   Reply With Quote
Old 03-01-2019, 06:16 PM   #3
Long Island , New York
The crucial factor for us would be the actual shower in the 22' "dry bath."
"Wet bath" showers are a compromise that is not worth it IMO.
No brainer agreed, if you can tow the 22' . . . good luck.
Peter
Old 03-01-2019, 06:26 PM   #4
Kanusport's Avatar
2019 22' Sport
Missoula , Montana
I don’t think you can go wrong with a 22 sport. The 16 is a great trailer and super cute and easy to tow. The 22 shares these characteristic with a light tow and tongue weight however the bed is much bigger. Also the bath is dry vs wet.
I’ll add two full size adults in the 16 bed is cozy maybe too cozy depending on your sleep habits.
I’m winter camping in my 22 right now and I love it.
Kanusport is offline   Reply With Quote
Old 03-01-2019, 06:31 PM   #5
Liquid Cooled
RedSHED's Avatar
2017 27' Flying Cloud
Columbus , Indiana
Dealing with friends and money is always a sensitive and potentially painful proposition.
We had a 16' for about 4 1/2 years and I really liked it. It was plenty for 2 adults, and 2 kids (13 & 17), all of us in the 5'6 to 5'10 range, give or take. I found it much more livable inside than the 31' we'd had earlier, not to mention easier to park etc. I also liked the way the bed(s) were set up better than the 22/23, but my opinion reflects my preferences, not some absolute value set.
The wet bath was never a problem for us, but quite probably not everybody has the same idea of camping either.
Full disclosure: since our oldest is now semi-independent, we don't need the space as defined by the 16', and have moved to a 27'.
RedSHED is offline   Reply With Quote
Old 03-01-2019, 06:54 PM   #6
2016 25' Flying Cloud
Holly Springs , Mississippi
The 22 is easier to see around, and has the larger bed. I can't think of a good argument for the 16, except that it scores very high on the cute scale. If you're OK on the overall length, the 22 is the winner.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 03-01-2019, 07:31 PM   #7
2019 22' Sport
Carlsbad , California
Like the others said, the bathroom alone is worth it. The larger bed is good, and you have more roof space if you plan to add solar. Saving $7K and getting a better trailer is a no brainer
Prettygood is offline   Reply With Quote
Old 03-01-2019, 08:03 PM   #8
Boise , Idaho
Thank you all so much, all of these replies are extremely helpful.
I'm a little concerned on the length and added weight of the 22' (i've never towed longer than a 6' dirt bike trailer). Will the bigger trailer reduce my mpg significantly more than the 16' will? Or would it be comparable? I think it's about 1,000 lbs. heavier.
Old 03-01-2019, 09:07 PM   #9
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
The only impact the heavier trailer will have on your TV will be the initial launch; yes it will take longer to get up to speed and will use more gas; it will also have an impact on braking performance; but once up to speed, the difference on mpg would be nominal, as both trailers displace the same amount of air, and it just comes down to rolling resistance.
Cheers
Sidekick Tony
PS Go for the 22'; you could always turn a 22' into a 16' far easier than turning a 16' into a 22'.
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 03-01-2019, 09:43 PM   #10
Rg416's Avatar
2019 22' Sport
Cohasset , Massachusetts
Hi, Iíd recommend the 22. The bed is 6Ē wider even though the trailer is 6Ē narrower. The dry bath it a huge upgrade, and it also has a grey tank and a black tank which gives you more capacity for boondocking. It also allows you to drain black first and follow up with the soapy grey tank which rinses your hose. It has a bigger fridge which is 3 way (LP 12v or 110v) vs 2 way. More storage, more counter space, and did I mention the bigger bed? We towed ours with a Volvo XC90 (5000lb tow capacity), and now a new Tahoe. Tows effortlessly with either.
I do like the dinette better in the 16. I like the 16ís fold down table better than the pedestal table in the 22 if youíll make it up into a bed. It is easier and faster to put down to a bed than the pedestal. And I donít like the U shaped dinette seats in the 22 as much as the facing benches of the 16. Only small children can fit on the bench on the long side of the table of the 22. The cushion there is very narrow. We just store food bags and stuff there.
But still, the bigger bed, the separate shower, and separate grey and black tanks make up for it. Hope this helps.
Rg416 is offline   Reply With Quote
Old 03-01-2019, 10:40 PM   #11
Martee's Avatar
2017 25' Flying Cloud
Waco , Texas
The 22' Airstream is actually easier to tow and much easier to back up than any short 10' utility trailer. A short trailer is very unforgiving and requires extremely quick responses to properly control. So don't fear towing a 22' AS. It also has quality brakes and suspension than any utility trailer.
I also originally choose the 16' Bambi, and within an hour of looking at other models and long discussion with my wife, we both decided on a Flying Cloud 25FB Model. I have never regretted the upgrade after almost 2 years travel.
Martee is offline   Reply With Quote
Old 03-02-2019, 01:01 AM   #12
1980 24' Caravelle
vallejo , California
go with the 22.as others have said, dry-bath and larger bed plus slightly more elbow room. the 22 will also be easyer to back-up. kurt
ke6gkv is offline   Reply With Quote
Old 03-02-2019, 03:18 AM   #13
2017 19' International
Tallahassee , Florida
Does the 22-footer have the vented AC?
If so, that'd be a big factor for me.
We had a 16, and we loved it. The AC was loud, though.
Our 19 has the vented AC, and, boy, what a difference.
I find the 19 easier to back up.
You may get better mpg towing the 22 than towing the 16, thanks to the 22's narrower profile. It's more slippery in the wind.
WhereStream is offline   Reply With Quote
Old 03-02-2019, 04:45 AM   #14
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
I'm going to weigh in in support of the 16 especially if you're just one person and you don't mind roughing it a little more (Airstreams are hardly roughing it nmw!). Less to take care of, super easy to tow and maneuver in tight spaces, bedroom in the rear for me is just super nice. I really love mine.
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Front and Rear TV Dilemma Teamaron Sprinter and B-van Forum 1 10-18-2017 07:00 PM
Sticker Shock! And Difference between 2015 and 2016 time2play Airstream Motorhome Forums 5 05-10-2017 09:17 PM
Here is my dilemma... buy now and wait or.... carl2591 Tow Vehicles 29 01-03-2014 05:29 PM
gotair's painting dilemma got me thinking... summerkid Off Topic Forum 16 04-16-2004 12:17 AM
