Old 10-15-2016, 09:44 AM   #1
2016 22' Sport
Clinton , Montana
I hate "intermittent" issues!
We have a 2016 22FB Sport...bought last March. i've put about 7000 miles on it since purchase and have spent close to 70 nights in it. Every now and then a small problem would pop up....door hinges coming loose, fresh water drain leaking etc. But, these for the most part, were tolerable....until our first long road trip.
We've just returned from a 5000 mile plus, 3 week trip from the western Rockies to the Appalachian mountains of West Virginia. Just prior to departure the radio/cd player quit...while on the road the heater quit and then one of the USB outlets followed suit. So much for enjoying those features when you most need them.
While parked for a week in WV I took off the heater cover and "low and behold" it came on! I cycled it several times before putting it back together and it worked just fine. After that...it worked all the way home..I'm glad...it got down to 22 degrees!
Also...while parked I checked the back of the radio to see if the speaker connections were loose. They were tight...so I pulled the plug out and as I was replacing it...the speakers came on. But, when I pushed it all the way in "it quite working". There was nothing I could do to get around this issue. So, we sat in silence for three weeks.
Upon our return home and after parking the trailer to un-load it...the radio came on by itself!
I realize all these items are covered under warranty but how do you get a dealer to repair or replace an item that is "working at the moment" but sure to fail once you leave their lot?
Rpatrick16 is offline   Reply With Quote
Old 10-15-2016, 10:05 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
It sounds more like an intermittent 12 volt problem rather than intermittent devices.
If you can get any one of the device to fail again check other 12 items, such as lights to see if is a given circuit. If no 12 volt items work ay=t that point check the battery cable connections.
2004 Excursion 4x4
Old 10-15-2016, 10:10 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
A-799, Most common response by Maintenance to Aircrew aircraft complaints. Navy Airdale/Maintenance types will get it.
MICHAEL
aaaaaaRRRRGGGGG! I hate UPS RichardT General Motorhome Topics 36 11-10-2005 02:52 PM
bah humbug! -or- why i hate x mas lights! john hd Off Topic Forum 7 12-05-2004 07:43 PM
i hate dem meeses to peeses..... norbert Our Community 4 04-11-2004 08:47 PM
