Old 12-29-2014, 09:37 PM   #1
onemoretime's Avatar
Solivita , Florida
Husband uses a C-Pap
If we bought a Bambi, is there anywhere near the bed to accommodate a C-Pap? I don't see even a small night stand in a Bambi, or in any of the models with a corner bed. What's an old RVer to do?
onemoretime is offline   Reply With Quote
Old 12-29-2014, 10:02 PM   #2
ntsbltsrvits
Cowbell's Avatar
2015 27' FB International
2016 30' International
Felton , California
Cpap
I always place my machine on the floor, even at home. I think it could also go in the closet in the Bambi. An 8' hose also gives more flexibility.
Cowbell is offline   Reply With Quote
Old 12-30-2014, 07:19 AM   #3
'15 Flying Loud 20' Bambi
renderit's Avatar
2014 16' Sport
small city outside a big one , south of some, north of some
I mounted a shelf above the bed on the back wall of the bathroom to hold my DVD player and a basket we throw keys in etc. No reason you can't do that. They cost about $20 at Home Depot and mount in about 10 minutes if you take your time. You could mount a smaller one on the closet side. And they actually match the decor...
renderit is offline   Reply With Quote
Old 01-27-2015, 03:40 PM   #4
2014 22' FB Sport
Atlanta , Georgia
Well, late to the party as usual. But I can only say:
Ouch. I regularly turn over and pull my CPAP off the bedside table in the middle of the night. Pulling it off that shelf might put me to sleep a little more permanently than I'm ready for as yet.
On my Sport 22, there's a bedside shelf, right at bed level. So it's really convenient. But I've also put it on the floor. The bigger problem for us is that my wife likes to sleep on the outside, I prefer the inside, and that tubing lays across the whole bed. But I've been tucking it into the crack between the bed and the wall and that seems to work out all right.
Belbein is offline   Reply With Quote
Old 01-27-2015, 10:25 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Our 1999 has holes in the cabinets to accommodate the machines. Thankfully we do NOT need at this time..
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-27-2015, 11:12 PM   #6
2007 19' Safari SE
Los Gatos , California
In our 19 footer, we have a storage cabinet with reading lights under it, over the bed. I put my CPAP up there and it works perfectly. It's off the floor, no danger of it falling off the shelf, and I can close the cabinet door as well.
RyeL is offline   Reply With Quote
Old 01-28-2015, 08:45 AM   #7
2007 19' Safari SE
Bambi & CPAP machine
I should add we have a 19' Bambi 75th Anniversary Edition. The bottom of the overhead cabinet isn't level so I put a book or something in there to level out the CPAP machine. Then I close the drop down cabinet door.
I bought the DC adaptor for my model of CPAP and run the power over to the DC power port so I'm running it off the battery most of the time because we rarely stay at campsites with full hookups. It draws very little power so a 2-3 night weekend trip not only isn't a problem, I don't see total battery life being significantly less than before I was using it.
Good luck working out a solution for your system.
Rye
Old 01-28-2015, 09:51 AM   #8
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
C-Paps are not just for "old" people.
This is the solution we have at our house.
Also, a nice battery for the Cpap can come in handy sometimes too. (For boondocking etc.)
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 01-30-2015, 05:24 AM   #9
renderit's Avatar
2014 16' Sport
I suppose if one was to use said shelf without using one's head and strapping the item in then one might get hit, yes. Shown DVD player is attached to said shelf. And I can only assume that if you "regularly" pull it off the bedside table they must be very inexpensive or you lack the common sense to correct the problem.' ]
By the by, the shelf above IS at the foot of the bed.
Old 01-30-2015, 07:46 AM   #10
2010 25' FB Flying Cloud
Davenport , Iowa
put the CPAP on the floor under the bed. Drill a hole in the plywood and run the hose up through at head of bed.
Don't forget to keep the filters, hose and mask clean.
Airtandem is offline   Reply With Quote
Old 02-04-2015, 05:06 PM   #11
2014 22' FB Sport
Atlanta , Georgia
Lack the common sense
Hey, Mom. Great to have you here!
South Boondocking with C-Pap Toppy Boondocking 10 03-28-2013 11:29 PM
C-PAP machines without shore power Blu_Hwy_Lady Off Topic Forum 12 04-07-2006 07:01 PM
