Old 01-27-2007, 07:34 AM   #1
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
How warm should I be ?
How much heat should I expect from the AC / Heat Pump combo on my new Bambi ?
I find I must put the thermostat all the way up to 99 to make the air coming out feel even a little warm.
Granted it was in the 30's here last night, but that jet on the roof never stopped and I woke up to only 67 inside here this AM.
With as hard as that thing worked and the small space is has to heat, I thought I should have awoken in a sweat with all the blankets on the floor !
Please advise.
Freezin' in Florida
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 01-27-2007, 07:50 AM   #2
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
First I thought 67' ...that's pretty good for the temps we are having here in New England but then I saw your "Freezin' in Florida"...... migration is not working for you...might want to add a small ceramic heater. I was amazed when we were camping in NH back in the fall how much heat was put out from the little unit. It got down into the low 30's and that's all we were using in our 21' and it kept us pretty toasty.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 01-27-2007, 07:54 AM   #3
2006 22' International CCD
St Petersburg , Florida
Heatpumps OK for cool, not Cold Weather
Good Morning, we woke up to 40 degrees this AM in Florida, and that is the lower limit for efficiency in these rooftop heatpumps. The output of air from a heatpump will always feel fairly cool (lower 70s) so your situation does not surprise me. Just fire up the furnace for a few minutes and you will be fine.
ASBear in Trilby, FL
ASBear is offline   Reply With Quote
Old 01-27-2007, 08:03 AM   #4
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Ditto - one tiny ceramic heater keeps our 25' Excella warm in cold weather. Keeps the propane furnace from kicking in which is a good thing as our furnace is wicked loud.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 01-27-2007, 08:08 AM   #5
bill benton's Avatar
Mansfield , Texas
I don't think the heat pump was ever meant to be the primary source of heat in a travel trailer. They work well to take the chill off. But just fire up that furnace and you will be able to enjoy plenty of nice hot air.
bill benton is offline   Reply With Quote
Old 01-27-2007, 10:04 AM   #6
TIMEMACHINE's Avatar
Huntington Beach , California
Freezin' in Florida
First of all, are you sure that you have the heat pump and not the heat strip? If it is the heat pump version, it was my understanding that it does not operate at lower outside temperatures, that being defined in the 30 degree neighborhood area.
as was stated earlier, the heat pump is not inteneded for primary heating, the LP furnace is the designated primary heat source and will get you sweaty if you turn it up.
TIMEMACHINE is offline   Reply With Quote
Old 01-27-2007, 10:39 AM   #7
cammur's Avatar
Roseville , California
"....First of all, are you sure that you have the heat pump and not the heat strip?"
OK, I'll bite. What is the difference between the heat pump and the heat strip?
On edit, my 2005 Safari has the heat strip, and my experience is much as described above. No help at really low temperatures, but some help if a bit noisy at mild temperatures. But what is a heat strip?
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 01-27-2007, 10:47 AM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Once my heat pump gets going it can put out 90 degree temps when we are in the mid 40's outside. Once you drop below 40 the heat output starts dropping. I find mid 30 outside temps marginal. There is a cut off where the thermostat will switch over to the furnace but at least in my trailer its far too low to keep the interior comfortable on heat pump alone.
The other thing that makes me wonder if you truly have a heat pump is that the heat pump has a defrost cycle. After a certain amount of run time (I forget what that is), the fan shuts down and the heat pump cycle changes to cooling mode while the compressor continues to run. This process causes the outside coils to warm which will defrost any ice which accumulates. If the unit ices up externally, you will get very little heat from the unit. You talked about the unit running continually, you should have noticed the defrost cycle, unless you actually have a heat strip equipped air conditioner.
The heat strip is electrical coils that heat the air through the blower. I had such a unit on my '01 Safari. It is limited in its ability to provide serious heat, and takes a long time to heat up when the trailer is cool. As I remember the strip cannot be controlled by the thermostat and is either on or off. I found it only useful when temperatures were in the 50's or at best upper 40's.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-27-2007, 11:04 AM   #9
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
As an aside, it doesn't matter if the thermostat is set to 70 or 99 degrees, as long as it's cooler in the trailer than 70 degrees. If the heater is on, it's heating. It doesn't put out more heat at 99 than it does at 70.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-27-2007, 03:06 PM   #10
2007 34' Classic
Pecos , New Mexico
I spend a lot of time in the trailer when it is cold out. I have found that the most efficient heat is the furnace and a small ceramic heater in the living area (only running when we are in the trailer). The heat pump only works well when it is above 40 outside and will go into defrost mode after a few hours of heating mode. It also sometimes helps to close off the bedroom if you can to concentrate the heat to the areas you spend the most time in.
Pecos Pete is offline   Reply With Quote
Old 01-27-2007, 03:55 PM   #11
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have an '05 Safari 25' FB and have camped in cold weather (for us native Floridians) quite a bit. We have probably spent 30 nights in Lucy (our Airstream) in temperatures at or near freezing. We have the 13,500 btu heat pump. We have found it to be more than adequate to keep Lucy toasty during the night. We have also used the gas furnace, and found it to be more than adequate.
Make sure that you have the heat pump rather the heat strips. You can determine this from the wall thermostat. If it is a heat pump, there will be a setting that shows 'heat pump' on the little screen.
If you do have the heat pump, it should work a lot better than you describe, especially on a Bambi.
SuEllyn & Brian McCabe
Old 01-27-2007, 04:13 PM   #12
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I had a heat strip in my Armstrong AC and it was my understand from posts years ago that it did nothing but take the morning chill out of the air in the trailer but it couldn't be very cold outside. I would think the newer heat strips would be about the same. I could feel the warmth but it was never hot.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-27-2007, 05:09 PM   #13
2007 34' Classic
Pecos , New Mexico
I had electric heat strips in my Bambi. Was told by the dealer that they were only good for taking the morning chill off - I agree. The heat pump will have an actual thermostat - at least mine does, not controls on the unit.
Old 01-27-2007, 05:21 PM   #14
I will try
Ok, there seems to be a lot of confusion about the difference between a HEAT STRIP and a HEAT PUMP. Here is my understanding with an option to be wrong without being flamed....
The heat strip is an electrical heating element which is located in the roof mounted A/C housing unit. It heats up and uses the A/C fan to distribute the heat off of the element into the AS.
The heat pump is part of the AC system as it is using the reverse process of the A/C cooling system to bring warm air into the AS, again using the A/C fan to distribute the warm air
Neither sytem is intended to be the primary heating source for your AC. The heat pump version is not in all A/C units, usually only the 13,500 and 15,000 btu units. The late model AS that do have the heat pump version are operated by the wall thermostat system and clearly shows "Heat Pump" as one of the modes of operation. It is my understanding that if this heat pump mode is selected and the outside temperature drops too low (somewhere in the 30s), the system automatically switches to the "Furnace" mode which is the LP heating system that is connected to the interior ducts found near floor level throughout the AS.
If there is someone with more experience please confirm and/or correct this attempt to explain.
2006 bambi
Fix when cold or warm? Becky B. General Interior Topics 12 12-26-2006 07:53 PM
Need help staying warm! dickwhite1 Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-09-2006 10:40 PM
Warm Welcome hantri Member Introductions 3 02-23-2006 04:59 PM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 09:08 AM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 11:10 AM
