Old 01-28-2007, 10:53 AM   #29
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by Pahaska
With the automatic switchover to furnace, I find the heat pump in my Classic 28 entirely adequate right down into the low 30s where it switches over to furbace. We set the thermostat at 70 to 72 and stay comfortable.
John, I wish mine worked that well. Unfortunately my 15K heat pump looses so much effiency once we get below the 36 degree mark that the inside trailer temps will drop below 70 and start getting mighty uncomfortable. Add to that the defrost cycles where you are getting no heat output, and by the time I get to the take over point where the furnace comes on line, we are pretty uncomfortable.
The other thing to keep an eyeball out for is running the heat pump when it's extremely humid and in the upper 30's. It's entirely possible to not run enough to engage the defrost cycle, yet run enough to start icing up on the exterior coils. Unfortunately the off cycle time isn't long enough to melt the exterior ice. I've posted a picture on another thread showing the exterior of my AC unit enveloped by ice.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-28-2007, 10:57 AM   #30
jcanavera's Avatar
Fenton , Missouri
Images: 143
Originally Posted by markdoane
I think you're right. If the thermostat is set near the ambient temperature, eventually the fan will shut off. I don't know whether its a thermal cool down, or just a timer, but i suspect its thermal.
The rating on the heat strip is 1530 watts, or 5600 Btuh. Take your pick, I don't know which is more correct.
I think that 5,600 BTU is pretty close. Pretty anemic when compared to your furnce that might be putting out 30,000-38,000 BTU's. This all raises an interesting question. Can we assume the heat pump has the same BTU rating on heating as it does on cooling?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-28-2007, 10:58 AM   #31
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I remember that photo and try to keep aware of what is happening on the roof. Fortunately our humidity is usually pretty low and it would be rare here to run into problems.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 01-28-2007, 12:55 PM   #32
cammur's Avatar
Roseville , California
Looking at a 2005 AS brochure, the Classic comes with heat pump, the International CCD and Safari come with the heat strip. The Safari is 11,000 BTU 19'-25', and 13500 for 28' (30' not listed). The International CCD is 11,000 on the Bambi 16'-19', 13500 on the 22'-28'.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 01-28-2007, 02:55 PM   #33
1976 25' Caravanner
Campton , New Hampshire
Jack
You're right , the heat strip does not compare in output to the furnace . 1500 w or 5600btu is about the most you will find on an electric heater ment to run on 120v , so it should be as good as any portable electric heater .
Interesting point about the output of the heat pump , somewhere it should be labeled , perhaps under the shroud where the AC specs are .
ticki2 is offline   Reply With Quote
Old 01-29-2007, 09:43 AM   #34
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Originally Posted by nohillgrish
However, if the heater is used too much your furnace doesn't cycle sufficiently to keep space around your holding tanks warm. Pretty important if you're "wet camping" below freezing.
Does that mean I should be running the HW heater also to keep that water from freezing ?
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 02-03-2007, 07:14 PM   #35
B4WEDI's Avatar
2006 19' Safari SE
Ya know.......... I gotta tell ya, making the heat is one thing, keeping it in and closing off cold air infiltaration is just as important if not more so !
I spent 5 hours or so with insulation, glue, caulking and duck tape, sealing some pretty big holes around water and waste pipes, around and under the bed over the basement storage area too.
MAN ! what a difference ! I think it's quieter in here too without the wind rushing through !
Nothing wrong with the heater now ! I also got a GE ceramic heater, works nice aimed at the shower in the AM !
You guys gave me lot's to think about, thanx for the guidance.
T & K
Old 02-03-2007, 08:44 PM   #36
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you have water in your trailer, yes run the water heater. A water heater full of water that freezes will split the tank open. Heating the water is the best way to prevent that. The small amount of propane used to heat the water is cheap compaired to replacing the water heater
Richard
Old 02-03-2007, 09:55 PM   #37
B4WEDI's Avatar
2006 19' Safari SE
Thanx Richard, I'll keep an eye on that fo' sho' !
T & K
Old 02-03-2007, 10:32 PM   #38
Just like in a house, a heat pump is designed to be a complimentary source of heat.
They are very efficient when the temps are above 40 degrees F.
The ceramic heater/heat pump combo works well when you do not want to burn a lot of propane and you are in a campground where you are paying for the electricity already.
Anon is offline   Reply With Quote
Old 02-04-2007, 04:01 AM   #39
B4WEDI's Avatar
2006 19' Safari SE
Got it, Coming from Cold Country, 40 degrees is warm, who needs heat ? Put on a sweater !
I never heard of a heat pump !
Sounds like it ought to do more than it does, But, I believe now, it is doing just what it was designed to do.
T & K
Old 02-04-2007, 11:22 AM   #40
Pahaska's Avatar
Hays County , Texas
Just attended a maintenance seminar two days ago. If the heater is less than 1/3 full, you don't havet o worry about freezing. There were tests by the heater manufacturer that proved this. They ran tests down to way below freezing.
This means that you don't have to go to any great length to get all of the water out of the heater.
ALSO, there is a new (more expensive) water heater out that will deliver more than 6 gallons of hot water. The water is heated much hotter than at present and there is a mixing valve that mixes in a measured amount of cold water so that the output is similar to today's heaters. Good news for those who want a long shower.
John W. Irwin
WBCCI #9632
2006 bambi
Fix when cold or warm? Becky B. General Interior Topics 12 12-26-2006 07:53 PM
Need help staying warm! dickwhite1 Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-09-2006 10:40 PM
Warm Welcome hantri Member Introductions 3 02-23-2006 04:59 PM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 09:08 AM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 11:10 AM
