Old 10-11-2013, 04:42 PM   #1
2014 19' Flying Cloud
Fallbrook , California
Question How to turn on/off Atwood Heater
We are new to Airstream. Can't quite figure out how the heater works in our 19ft Flying Cloud. Can someone help? Thank you.
sabbott is offline   Reply With Quote
Old 10-11-2013, 04:50 PM   #2
2007 22' International CCD
Heater
If we're talking the furnace to warm the interior, the thermostat controls that. Be sure the mode slide switch is set to HEAT and the temperature is set right.
If you mean the hot water heater, there should be a rocker switch somewhere to turn it on..
Old 10-11-2013, 05:43 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Furnace vs. Heat Pump
Set the Mode to "Furnace"
Give it a few seconds to think about it and then the furnace will kick in as long as your batteries are charged (or you are plugged in to shore power) and your propane tanks are open.
On shore power, you may also have a "Heat Pump" option among the modes on your thermostat.
The heat pump (if so equipped) will not work on battery power alone. It is a 120 VAC device.
The furnace is designed for boondocking and works on propane and 12 VDC.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-11-2013, 05:57 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I am assuming you mean the furnace. Once you (1) have the thermostat turned on (there's a sliding switch on the bottom of the wall thermostat), (2) you'll need to set it to "furnace" (or it may say "heat"), and (3) have the thermostat set at a temp low enough so that the furnace will come on ... there will be a bit of a delay and the furnace should come on. (This assumes your propane is turned on.) First you will hear the blower start, then you'll hear a click-click-click of the ignition...then you should hear the propane furnace light, and you'll have heat coming out of the furnace vent. If you have not used the furnace in some time it will have that odd furnace smell until it "burns off" the dust, etc.
TB & Greg and Abbey Schnauzer
#3954
Old 10-11-2013, 06:08 PM   #5
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Most likely you have the digital CCC II thermostat which does not have the sliding switches.
Products - Dometic
Here's a link. You can find the manual on this page, if you didn't get one with the trailer. It really isn't too hard to operate, but can be a little confusing. Push any button to wake up the tstat. Push mode until you get to furnace. Turn up the temp with the arrow keys.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 10-11-2013, 06:53 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Ah ... I stand corrected ... a newer way to turn the thermostat on! Thanks, Dave.
#3954
Old 10-11-2013, 07:01 PM   #7
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I'm sorry, didn't the people you bought it from give you a walk through?
Ahab is offline   Reply With Quote
Old 10-11-2013, 07:15 PM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I know from experience that after about ten minutes, the customer's eyes kind of glaze over, and all they hear after that is "blah, blah".
To operate the furnace using the ccc2,
Push the power button until the display lights, then push the mode button until "furn" is displayed. Select the temperature using the up and down arrows to the right of the display.
Old 10-13-2013, 11:54 AM   #9
Thank you all.
