Old 06-13-2019, 01:25 PM   #1
2019 22' Sport
Santa Fe , New Mexico
How do you open rear window in 22fb 2018 from inside
How do you open rear window in Sport 22fb 2018
Cherokee88 is offline   Reply With Quote
Old 06-13-2019, 06:24 PM   #2
2019 22' Sport
High River , Alberta
The bathroom window? There should be a round plastic knob on the right side. I believe you turn it clockwise to open.
AlbertF is offline   Reply With Quote
Old 06-14-2019, 10:56 AM   #3
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
If you're talking about the bedroom window (big AS(s) single pane (pain)) then you don't. But it is easy to do this:
You open the latches from inside then go outside and 'gently' lift the glass edge away from the rubber gasket using your fingers or a plastic item. From the outside it is easy to snap the side locks. Viola.
Reversing the process is easy too. No need to get into bed to do anything until you need to close the latches.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign K5FT
Msherw is offline   Reply With Quote
Old 06-14-2019, 08:45 PM   #4
2019 22' Sport
Waynesville , Missouri
If youíre talking about the bathroom window, thereís a knob in the bottom right corner. Our window was stuck in the frame at first. I had my better have put a little twisting pressure on the knob and I pulled open the bottom of the window. There was a little bind at first, but once it popped open, it worked like a charm.
DAVSCH is offline   Reply With Quote
Old 06-15-2019, 08:54 AM   #5
2019 22' Sport
Many thanks problem solved
Old 06-16-2019, 02:16 PM   #6
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Glad you got it figured out.
M!ke
AS 22FB- how many/type of Lithium can be install inside waninae39 Batteries, Univolts, Converters & Inverters 12 03-07-2018 06:47 PM
Does anyone have experience modifying the rear escape window to open from inside 19' pkm123 2005 and newer - Bambi all models 13 05-07-2017 11:36 PM
Have you ever wished that your Interstate's rear door windows could open?! InterBlog Sprinter and B-van Forum 8 06-22-2016 05:45 PM
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
? Idea for holding open rear window, '05 19' CCD Chilao Windows & Screens 5 08-19-2005 08:42 AM
