04-25-2007, 06:55 PM
1976 31' Sovereign
2007 19' Bambi
Midland
Hitch Ball question
Hey everyone.
Does anyone know the required hitch ball diameter/size for the 2007 Bambi 75th Anniversary Edition?
We're heading to pick up our new aluminum and I thought I'd better check this particular item before we leave.
Thanks for your help.
04-25-2007, 07:26 PM
Naples
The frame is the same as on my 19CCD I believe. I use a 2-5/16" ball. Yours should be the same, as are all newer Airstreams.
lewster
04-25-2007, 07:39 PM
1976 31' Sovereign
2007 19' Bambi
Midland
Thanks Lew.
Somehow I knew I had the wrong size. Quick trip to U-Haul before we hit the road then.
I really appreciate your help.
04-25-2007, 07:44 PM
Naples
Have a 'BALL"........
Sorry, just couldn't resist!!!
lewster
04-25-2007, 07:57 PM
St. Cloud
Racoco -- Make sure you get something close to a 10,000# rated ball. It may be more heavy duty than what U-Haul has, but then that's only guessing. An RV dealer should have one and I'd almost think your Airstream dealer would too. The shank is huge compared to a normal ball and this is what it takes to fit in weight distributing hitches. The shank is larger than the biggest part of your thumb. Have an awesome ride!
04-25-2007, 10:06 PM
1976 31' Sovereign
2007 19' Bambi
Midland
Bob -- Thanks for the tip. As many times as I have looked at it, I can't remember... does the 19' Bambi come with a weight distribution setup? I'm going to find the larger ball; just curious at this point.
Our tow vehicle is rated above all the weights I've got for the 19-footer, so I never really thought about weight distribution. Sway control I'll have to work on.
And Lew... I wouldn't have passed on the pun either; but I'm the one that set that one up.
Thanks guys.
04-26-2007, 01:02 AM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
Congratulations on your new Airstream.
Unless your dealer threw one in with the deal, you're going to have to purchase the weight distrubution system. I would strongly reccomend getting one before you tow your new Airstream. I already had one for my 68 Trade Wind, but as part of the orientation my dealer offered to hook it up and make the necessary adjustments for the Bambi.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
04-26-2007, 04:47 AM
St. Cloud
Is it too late to throw in 'bollocks' ... Where can I buy some of this resistance stuff?
Racoco -- WD & antisway are strongly advised regardless of the size or capacities of your tow vehicle. If you leave it to the dealer they'll probably put on some off brand gear. 'Less expensive' may even get you a friction antisway that requires continuing adjustment (PITA) and may lose effectiveness in wet conditions. Weight distribution and antisway come in the same apparatus. A member recently posted that lighter Equal-I-Zer bars are hard to come by for smaller Airstreams. My experience and others is that the Reese HP (high performance) Dual Cam is hard to beat. Give your dealer a call -- if not on hand I'm sure they could have it from a regional supplier in a day or two.
04-26-2007, 06:04 AM
Naples
I use the 600# bars on my Equal-I-Zer for my 19CCD. Works GREAT! In fact, the van rides BETTER hooked up than by itself!
When you look for a ball, get a 1-1/4"shank. They have the highest weight ratings. Overkill here is good thing .
lewster
04-26-2007, 06:14 AM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
Originally Posted by racoco
Hey everyone.
First off-welcome!
I'm going to chime in also; I hope you get more than just a "ball" before you hook up. All of the above posts are true. You didn't say what your TV is but, anti-sway and WD are always a good idea and may even be mandatory based on TV specs. You would not want to leave the dealer with your new Bambi and end up in the ditch a mile later (it happens).
I use an Equalizer.
Best of lick, Bill
05-04-2007, 08:04 AM
2007 19' Bambi
Ottawa
Congrats racoco!
Nice to fine another 75th owner on here!
We have the 600lb equalizer and have been quite happy with it. Doesn't interfer with the propane line either which I gather is an issue with some setups.
Enjoy! Look forward to hearing how the 75th works out for you.
Cheers
Dave
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Hitch height help
daydreamer36535 |
On The Road... |
6 |
12-26-2021 02:41 PM |
Hensley Arrow Hitch
Les |
Hitches, Couplers & Balls |
116 |
12-14-2015 07:41 AM |
Hitch light plugs
ALANSD |
Brakes & Brake Controllers |
4 |
10-12-2002 09:04 PM |
class 3 hitch
paul rogers |
3 |
08-17-2002 05:53 PM |
Hitch problem
wyhjr |
8 |
07-22-2002 05:29 PM |
