Do any of the burners work? Is there a valve in the line going to the stove? Can you put a pressure gauge on the main propane lin , it should read 11" water column. If it does' you could have a bad regulator. Last suggestion is turn off the tanks, disconnect the propane line where it goes into the stove, use 2 people one to open the tank the second to listen, feel and smell for gas, put a gauge on the line where it enters the stove. 11" WC? Yes, the problem is in the stove No, the problem is in the line. Turn off the tank quickly and make sure there are no ignition sources. It is not uncommon after changing tanks to have air in the line which will take a few minutes to bleed off.
