Old 08-25-2016, 10:44 PM   #1
Boxite's Avatar
2008 22' Sport
Getting Piezo'd off with stovetop ignition
Anyone else experience this problem: The little 2-burner cooktop in the Sport has piezo ignition. So,... hold IN the burner-knob (to start the flow of propane) then push the piezo button...and a nice little spark jumps from the post to the burner..... but NADA. No light!
Do it again. And again. And again. No light.
Get out the BBQ-lighter and push the burner-knob while holding the lighter-flame nearby..and WHOOSH! We got a burner working just fine.
Now the goofy part: The piezo will light 'er up just fine if I turn off the burner and back on to test the piezo. This will work for several minutes.
But if the stovetop is cool...the piezo spark just won't light the gas. I can see the spark. I can hear the gas. But no spark from that piezo will light it. But the BBQ sparker will do it every time.
Anyone?
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-26-2016, 06:03 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I have found that ours lights easier with the Piezo if I start it by holding in the gas control knob on the high position rather than the light position. Also it appears that part of the Piezo is a thermocouple so you need to hold in the gas control knob for a few seconds with the flame until it warms up otherwise the flame will go out.
Using the BBQ lighter is also a lot quieter, so I use it first thing in the morning.
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 08-26-2016, 07:18 AM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
I gave up on the 'pizzo'....
The 'clicker' is always handy....
PFC
but I’m the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-26-2016, 08:21 AM   #4
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Yep. Same thing with mine. I quit trying to use it & just use a lighter. :-(
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-26-2016, 12:51 PM   #5
HoffmanP's Avatar
2014 27' FB International
Prospect , Virginia
Go to Walmart and buy several feet of that 1/2" corrugated tubing for holding wires together. Run each of your piezo wires through that tubing. It helps insulate the piezo wires and your lighters will work much more reliably.
Paul Hoffman
2014 27FB International (WBCCI # 5327)
VA Plate: SOJOUNR
2013 Ford F-150 XLT Super Cab (Silver)
VA Plate: TRL DUST
HoffmanP is offline   Reply With Quote
Old 08-26-2016, 12:53 PM   #6
1994 30' Excella
Mississauga , Ontario
Make sure the gas tubes that run from each burner to the piezo lighter are installed correctly. Mine come undone when travelling.
Al
Al and Jean
TAC ON-3
Old 08-26-2016, 01:25 PM   #7
Boxite's Avatar
2008 22' Sport
Hoffman, the piezo fires a nice spark reliably every time. It's a 1/4" spark that jumps from the piezo-tip directly to the burner-plate crossing the direct path of the flowing gas. That's not the issue. The gas simply doesn't light.
BigAl, the gas flows wonderfully from the burner as evidenced by the flame-pattern when I light it with a BBQ lighter. It's a nice, even, large, blue/white flame with yellow tips.
I am stumped.
Rambox
Old 08-26-2016, 02:44 PM   #8
richw46's Avatar
Lexington , Kentucky
We use matches or a Bic too. Sometimes ours will light just fine, sometimes you have to light one burner with a match and the other two will light fine, sometimes the knob is not exactly on 'light', sometimes any of them will light with a spark, sometimes there are too many clouds in the sky or the sun is in the wrong position...
I don't like to hear propane gas hissing and the wife snapping that piezo igniter thing for a couple of minutes, scares me. I've seen people lose eyebrows and arm hair trying to light a gas grill.
1. Light the Bic long neck lighter next to the burner
2. Turn the burner on
3. Cook
Keep it simple, soldier
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-26-2016, 04:42 PM   #9
Native143's Avatar
2014 16' Sport
Dunedin , Florida
Me too. Same thing on my Bambi. I'm thinking that after cooking on it previously there may be residue from cleaning up afterwards that gets on the end of the piezo lighter. If after a couple tries it doesn't go, I grab the lighter also. It lights after that with no problem.
"I'd rather rust out than wear out"
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 08-27-2016, 08:31 AM   #10
2000 25' Excella
Northern , California
We find that if you give it a second after turning on the gas before operating the piezo, then while standing erect, blow a gentle puff or two of air toward the subject burner while operating the piezo. It reduces the failure rate considerably, but not perfectly. Sometimes, you just have to use a hand-held igniter.
Kamiak is offline   Reply With Quote
Old 03-10-2017, 12:21 PM   #11
2014 16' Sport
San Diego , California
I'm in the process of replacing left burner on 2014 Bambi 16f. Had same problem. AS warranty is covering it.
Karrylou is offline   Reply With Quote
Old 03-10-2017, 02:55 PM   #12
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
A couple of comments. It takes a few moments for the gas to clear air from the line from the valve to the burner. Ours was inconsistent and we mentioned it while at a stop for routine maintenance at Jackson Center. They adjusted the gas pressure at the propane regulator on the tanks and it has worked fine since, and the water heater lights more consistently on the first try. Don't ask me how that adjustment is done, they did it while we were on the factory tour.
Doug and Cheryl
Old 03-12-2017, 11:46 PM   #13
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
Fredericksburg , Texas
We were having similar issues with our 22FB water heater. Our situation went away once I purchased new tanks and started taking them to the local LP Dealer to get refilled instead of using the more expensive but more convenient tank exchange at Lowes.
twbucksr is offline   Reply With Quote
Radio not working when ignition off ChromeNomad Sprinter and B-van Forum 13 04-12-2016 09:18 AM
Piezo Lighter problem... Joebanjo General Appliance Topics 0 08-25-2013 04:33 PM
Freestanding LP Stove with Piezo Ignition VAbirdwoman Stoves, Ovens & Microwaves 1 07-31-2012 09:44 AM
where can i find a new stovetop roadtrip07 Stoves, Ovens & Microwaves 1 07-13-2005 03:11 PM
Stovetop & Hubcap lmbando 1974 - 1979 Sovereign 5 08-16-2004 10:39 PM
