Old 01-19-2016, 08:49 PM   #1
estegmann's Avatar
2012 19' Flying Cloud
San Diego , California
Furnace Noise
On a recent trip, we used our HP and Furnace and noticed a thumping sound periodically. Both systems seemed to warm our 2012 19' Flying Cloud just fine however the noise was very noticeable. Does anyone know what may cause this and whether it might be a simple adjustment or something more...I contacted airstream and they said it could be the HP working hard due to the low temps and recommended we switch over to the Furnace. I did as recommended and the noise persisted. Any help would be appreciated.
estegmann is offline   Reply With Quote
Old 01-19-2016, 11:13 PM   #2
richw46's Avatar
Lexington , Kentucky
Sounds like the noise happens with either HP or furnace. Does it happen after either has been running a while? If so, I'm guessing a piece of aluminum is flexing as it warms up. Can you locate the sound? Since heat rises, I'll bet it's a ceiling panel.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 01-19-2016, 11:22 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Doesn't need to be aluminum. Can be any metal including the furnace and ductwork.
Old 01-19-2016, 11:41 PM   #4
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Any chance you could record it and post it? Maybe a video and put it on YouTube? Our heat pump is noisy when it kicks in and our furnace is hardly a mouse, not a thump though..
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is online now   Reply With Quote
Old 01-20-2016, 01:07 AM   #5
estegmann's Avatar
Yes! It does start only after the unit has been running awhile. I've tried to isolate the sound and initially thought it was coming from the duct. Will need to spend more time now that we're home from our trip. Does this sound like something that may simply need adjustment or that which we'll just need to live with?
Old 01-20-2016, 04:40 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
A heat pump will thump when the compressor cycles, just like it does in air conditioning mode. But the sound wouldn't come from the furnace duct. They are separate systems so it's hard for me to figure where the thump would come from on both. Unless it is just something in the camper warming up. Maybe oil canning of the belly pan?
2012 Dodge Durango Hemi/AWD
Old 01-20-2016, 08:18 AM   #7
richw46's Avatar
It could be something in the AS too, doesn't have to be part of the trailer. In my garage is a metal can of Coleman fuel, nearly empty. When I open the garage door, depending on the weather, I'll get a nice clunk when the air hits that can and expands or contracts it.
-Rich
Rich & Yvonne
2004 4Runner SE
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 12:18 PM
Furnace Blower Noise Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 22 03-01-2013 12:00 PM
Slight noise from a Suburban furnace nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 12 02-09-2010 06:36 PM
Furnace Vibration and Noise flyfisherman Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-16-2005 08:37 PM
**Furnace Noise** Silvertwinky Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-07-2003 04:42 AM
