Old 12-09-2018, 05:36 PM   #71
2007 22' International CCD
First day with Sport 22FB
Try plugging in the umbilical and turning on the running lights on your tow vehicle.
Some cameras are wired directly to clearance lights to get power.
That’s the way I wired mine when I installed them. I drive with all lights on whenever I am towing so hopefully I am easier to see.
Old 12-10-2018, 07:20 AM   #72
1962 22' Safari
Leo , Indiana
Originally Posted by Casa Air View Post
We are brand new with our first RV is a 22 FB Sport. We took delivery 12/4. We have a Voyager Digital Wireless Monitor that I am having trouble getting paired.
The coach is in the driveway plugged into city power.
I backed the TV up and plugged in to the coach.
I followed the. Pairing instructions and it failed each time.
One of the responses was to turn them power onto the camera. I don’t see any switches on the camera so I am uncertain if the camera is not receiving power from the factory’s wiring or if I am missing something in the set up
The coach is not hooked up to the TV should I unplug city power or is this an install error and dealer help is required
I appreciate your help
Is it powered by your running lights?
Jimroll is offline   Reply With Quote
Old 12-10-2018, 08:00 PM   #73
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Just piling on about the camera.
Factory install is via the running lights. TV lights must be on to activate the camera. After that, be sure the video is set to the correct channel. If all else fails, go back to the selling dealer or the AS Mothership.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign K5FT
Msherw is offline   Reply With Quote
Old 12-10-2018, 08:07 PM   #74
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Originally Posted by PatLee View Post
I wonder why a stove vent wasn't built in to your model.
Simple answer $$. The vent would add both weight (not much) and cost. The 22FB is a single axle and sells for under $60k. Keeping weight under gross 4000ibs is a huge marketing tool.
M!ke
Old 12-11-2018, 04:33 AM   #75
2019 25' International
Washington , Washington, D.C.
Msherw - My last AS was a 19' Int'l Bambi and it had a stove vent. Given all the cautionary advice about how to prevent moisture/humidity from accumulating inside ASs, you would think a vent would be automatically included on all models.
PatLee is offline   Reply With Quote
Old 12-11-2018, 12:28 PM   #76
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Well AS did fit the Bambis with a Fantastic Fan roof vent. It acts as a good air extractor. I guess they felt this was a cost effective way to pull cooking fumes out under most conditions. (yes one window should be slightly opened to get good cross ventilation as some said.)
Someone here said there is interior moisture buildup using the AS furnace. No. The furnace burning LP vents to the outside of the furnace housing. The only moisture build up inside is from the cooktop stove and hot water showers (and humans breathing during sleep hours). In all cases the roof vent likely is adequate.
We do most, if not all our greasy cooking on a griddle or Coleman stove outside on a picnic table. If too cold to do that, we just use the microwave for warming already cooked food. We feel the cleaner and better smelling our AS can be, contributes to our enjoyment. Would I like a Balderi vent-a-hood? Sure. Just not necessary. BTW Winnane ?? added one to his 22FB. Lot of work but sure looks great!
M!ke
22FB Sport :: 2012 Airstream Sport Bonita Airstream Registry Discussions 0 03-29-2017 02:23 PM
First AS, thoughts on this 22FB Sport Maddmike 2005 and newer - Bambi all models 10 04-19-2016 01:16 PM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
bad day airstreaming beats good day a power company part 2 john hd Off Topic Forum 9 02-13-2004 08:12 AM
bad day airstreaming beats good day at power company! john hd Off Topic Forum 5 01-29-2004 04:04 PM
