Old 08-27-2018, 05:43 AM   #57
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
Originally Posted by Coastalphoto View Post
Bathroom vent. Open the window. Sure you freeze your bum off in winter, but ok.
Biggest regret is no stove hood/ventilation. I set that darn smoke alarm off ALL THE TIME. Maybe you are vegan and don’t eat bacon. Maybe you can cook the bacon outside.
I have field-tested suggestions for these 2 points.
Bathroom vent-We found that keeping that bathroom window cracked open was important year round. Why? You are breathing in and out all night and the trailer will get clammy and uncomfortable if you don't have some way for that humidity to leave.
Important when running AC since it may not kick on much at night and you don't want to be hot and clammy.
Important when running the furnace too, because propane will add humidity to the space too. Don't want to be cold and clammy.
(on our current 25 we keep the vent open but off in the shower-same idea)
Bacon-Check out Costco already-cooked bacon. Just crisp it up. No huge hot pan full of dangerous grease to manage, but a nice bacon-y essence in the pan for cooking those pancakes.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 08-27-2018, 07:24 AM   #58
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Originally Posted by ladyb2cool View Post
Hi. What tires do you have on the airstream? Do you still have the dealer tires on there? If you’ve upgraded, what did you upgrade to? Thanks so much!
I have the OEM Goodyear Endurance that AS began using in 2018. They have been great. Just got to keep them at 80psi for correct load handling.
But I don’t want to stray off this thread topic. So private message me if you need info or just search the forum for tire help.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign K5FT
Msherw is offline   Reply With Quote
Old 08-27-2018, 08:16 AM   #59
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we ordered a kitchen exhaust from AS factory. Its installed and works well. be sure to seal all the gaps before installing to ensure air only goes in one direction. instead of cutting a whole in the cabinet ( and loosing space) ours hangs below the cabinet ( its 2" lower that what the factory does)
We keep the sink window open a bit and now get a very good breeze from that window across the stove and out
look in this area for pics i posted some time ago
waninae39 is offline   Reply With Quote
Old 08-27-2018, 05:03 PM   #60
2011 22' Sport
Portland , Oregon
Actually, the furnace will not contribute any increase in humidity to the interior. The furnace is a sealed combustion unit with a heat exchanger, this means none of the combustion air (or the h2o byproduct) goes to the interior of the trailer.
Anytime you increase the temperature of air it decreases the relative humidity. If you are seeing an increase in humidity it is likely just due to having the small chamber that is an AS closed up more in the cool weather, and the humidity source is you and your activities within the AS.
SilverHouseDreams is offline   Reply With Quote
Old 08-27-2018, 06:03 PM   #61
waninae39's Avatar
2017 22' Sport
NCR , Ontario
this is what our exhaust fan looks like
ID:	321008   Click image for larger version
Name:	finished shroud.jpg
Name:	fan with light.jpg
Old 11-13-2018, 09:34 PM   #62
That looks nice thanks for sharing
Kanusport is offline   Reply With Quote
Old 11-15-2018, 06:59 PM   #63
2019 22' Sport
Santa Fe , New Mexico
we bought a bigger, higher quality TV/monitor it also has a built in DVD.
we ran a new audio cable along the RS wall and plug it in the amp. then select AUX input
we also replaced the cheap speaker with better ones
Yes I did the same. Cherokee88
Cherokee88 is offline   Reply With Quote
Old 11-15-2018, 07:03 PM   #64
2019 22' Sport
Yes I did the same
Old 11-27-2018, 05:56 PM   #65
Miami Beach , Florida
Bambi 22FB questions...
Does anyone know if it is reasonably possible to modify the Sport 22FB:
1. add or expand the more fresh water capacity ?
2. add or expand the gray and or black water capacity?
3. add or expand the rooftop solar panel maximum capacity?
thank you!
rsementi is offline   Reply With Quote
Old 11-27-2018, 06:01 PM   #66
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
thank you!
I guess all “can” be done, it’s just a matter as to what effort and $$ you are willing to expend for said upgrade
I’d say
1. Freshwater Carry a Jerry Can
2. gray/black Carry a BlueBoy
3. Solar. You can probably get 400 watts up on the roof and another 200 watts portable.
Old 11-27-2018, 11:17 PM   #67
2011 22' Sport
Portland , Oregon
thank you!
How much solar do you actually need? Your first best path is to look at reducing how much battery you consume, then look at maximizing the charge window you have (lithium batteries?)...and then perhaps look at how to get more solar. The best way to get more than what will fit on the roof are solar suitcases.
Old 12-09-2018, 08:17 AM   #68
LuLuAdrift's Avatar
2016 22' Sport
Leesburg , Florida
Welcome AACreek! I towed my 2016 22'FB Bambi with a 2007 Tacoma for 15000 miles (until a recall on the frame & rebuilding issues!) I suggest you keep it at 60mph unless you need to pass, even then only up to about 65mph. Cargo storage in the camper is extremely important so don't carry weight in the bathroom...keep it forward. CanAm also noted that the Sport tows better with full freshwater tank. Do weigh your truck alone, and then truck fully loaded with camper. It is easy to carry too much so please be aware of your weight limits.
I now have a Tundra and after getting used to it, do like the heavier brakes and V8...but pay for it with gas mileage. Oh well there are trade-offs.
Happy travels! Be sure and go to some rallies...AS community is the best.
LuLuAdrift is offline   Reply With Quote
Old 12-09-2018, 09:15 AM   #69
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by aacreek View Post
Here are pictures of my setup as we drove it home. Unfortunately we could not find a good deal in Texas so we purchased at Chilhowee in Tennessee.
We are getting a bed cover regardless for secure storage. Maybe that will help. Towing on the way home was fine, not too many issues with sway. I am not crazy about the eaz lift with the sway bar. I really liked the Andersen we had with our previous trailer.
Also is a picture of some items that “shook” out onto the floor. I am hoping they were just left behind during construction and not anything important.
Thanks for all the input.
Attachment 320451Attachment 320452Attachment 320453Attachment 320454
Unstable towing...
The AS rear looks a bit low...get level and check weight distribution. (returned weight to TV front axle and proper TW when hitched & loaded).
Shorten up your chains & cross under/between the WD bars.
Name:	06 BURB SHAKEDOWN TRIP 018.jpg
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 12-09-2018, 05:27 PM   #70
2019 22' Sport
Poway , California
First Airstream
We are brand new with our first RV is a 22 FB Sport. We took delivery 12/4. We have a Voyager Digital Wireless Monitor that I am having trouble getting paired.
The coach is in the driveway plugged into city power.
I backed the TV up and plugged in to the coach.
I followed the. Pairing instructions and it failed each time.
One of the responses was to turn them power onto the camera. I don’t see any switches on the camera so I am uncertain if the camera is not receiving power from the factory’s wiring or if I am missing something in the set up
The coach is not hooked up to the TV should I unplug city power or is this an install error and dealer help is required
I appreciate your help
Casa Air is offline   Reply With Quote
22FB Sport :: 2012 Airstream Sport Bonita Airstream Registry Discussions 0 03-29-2017 02:23 PM
First AS, thoughts on this 22FB Sport Maddmike 2005 and newer - Bambi all models 10 04-19-2016 01:16 PM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
bad day airstreaming beats good day a power company part 2 john hd Off Topic Forum 9 02-13-2004 08:12 AM
bad day airstreaming beats good day at power company! john hd Off Topic Forum 5 01-29-2004 04:04 PM
