Old 08-25-2018, 12:17 PM   #43
2011 22' Sport
Portland , Oregon
I think I will disagree on the 5000BTU being adequate. It takes quite some time with any level of humidity to cool the trailer down from 98 degrees from a long hot sunny drive and parked in the sun...the 5k BTU might never catch up once it falls that far behind.
SilverHouseDreams is offline   Reply With Quote
Old 08-25-2018, 01:08 PM   #44
keweenawbee's Avatar
2018 22' Sport
eden prairie , Minnesota
Originally Posted by aacreek View Post
I only took pictures of what wasn't connected. Attached are additional photos. TV does not have audio out or Bluetooth. Going to have to upgrade TV for sound through speakers.
Attachment 320684Attachment 320685Attachment 320686Attachment 320687
Yeah that looks pretty good. If you have the JVC mobile DVD unit and the LG TV on a mount like I did (I removed them for LG 4K monitors) The sound did work both directions through that HDMI cable and the USB powered adapter that I see in your photo. One of the first things the salesman showed me (probably to get my mind off other things) was the TV pulling in a local station and the sound playing through the ceiling speakers. When you play a DVD it feeds the sound to the TV speakers (in addition to the ceiling speakers), but when you play off the TV's tuner it somehow fed the sound back to the JVC for amplification too.
2018 Sport 22fb
Ford Transit 250 Quigley 4x4
Gitchee Gumee on the Keweenaw Peninsula
keweenawbee is offline   Reply With Quote
Old 08-26-2018, 09:34 AM   #45
2016 25' Flying Cloud
Frisco , Texas
Hi! What tires do you have? Thanks
ladyb2cool is offline   Reply With Quote
Old 08-26-2018, 09:39 AM   #46
Frisco , Texas
Tires?
Originally Posted by Msherw View Post
Great to hear your first trip went well. I echo all your noted shortcomings as our 2018 is missing the same. But we have learned to live with(out) them.
We tow with a 4Runner (essentially a Tacoma) and use an Equi-I-Zer WD and anti sway that makes the trip surprisingly relaxing. It has been great in our 6000 mile journey thus far.
The 4RUNNER is a bit heavier than the Tacoma and the setup never allows the “tail to wag the dog” so to speak. Your Tacoma may be getting some shimmy due to air slipstream drag in the bed. A tonneau cover fixes that. I tow 75+ and have to look in the rear view to know Baby Doe is still in tow. Keep the tires filled to 80psi.
We added custom teakwood flooring mats to the shower and bathroom (teakworks4u.com). Made a lot of difference in our comfort and floor cleanliness during a long trip. All in all I think the 22FB is a great choice for a compact RV that is built to last.
Welcome to club.
Hi. What tires do you have on the airstream? Do you still have the dealer tires on there? If you’ve upgraded, what did you upgrade to? Thanks so much!
Old 08-26-2018, 11:42 AM   #47
1962 22' Safari
Leo , Indiana
Shouldn't need much light outside this time of year. Enjoy the firelight.
Jimroll is offline   Reply With Quote
Old 08-26-2018, 01:07 PM   #48
bmc5311's Avatar
2019 30' International
Pearland , Texas
I had the same TV/sound issue - I played around with the tv settings and got it to work, I think I had to turn off the external speakers or something non-intuitive to get it to work, I also think the stereo receiver has to be on.
bmc5311 is offline   Reply With Quote
Old 08-26-2018, 03:23 PM   #49
2018 22' Sport
As for the LG tv we just ignore it. Good for early morning over the air HD news updates when a/c noise level is minimum. But for evening movies we use our iPads and Bluetooth headsets to enjoy personal time during noisy a/c runs. AS missed the boat putting such a low priced tv in the rig and not running the audio into the JBL. Yes, change the tv if that is a priority.
Just a quick note on this. We added an Apple TV box to the trailer AV system which gives us access to most of our DirecTV home subscription without dragging a dish around with us. Only negative is the lack of the DVR commercial skip feature which wastes time. I have found that some programs we watch at home however are exclusive to the iPad but are easily moved to the TV screens via Airplay sharing through the Apple TV box (requires fairly good broadband, we have 5mb/sec where the AS is parked most of the time)
Kind of feel like we've joined the 21st century by finally learning this cord-cutter methodology out of necessity.
2018 Sport 22fb
Old 08-26-2018, 04:11 PM   #50
2017 22' Sport
Lancaster , California
Just got my 22FB in early 2018.
For exterior lighting when on shore power or generator I use a strand of warm LEDs on the awning ..
My hubby wired my running lights so that I can run them off the battery and thats what we use most of the time. They provide enough light to be helpful without being annoying to us or others if we are in a campground.
ID:	320902   Click image for larger version
mammothmama is offline   Reply With Quote
Old 08-26-2018, 04:37 PM   #51
2017 22' Sport
For ventilation in the bathroom we crack the window and run the fantastic fan at the same time. Ditto for the cooker... crack the kitchen window and run the fan.
We did upgrade the TV to a larger smarttv with 2 hdmi inputs so we can stream prime/netflix/news apps or play downloaded content from devices but weve yet to sort out the audio because weve been too busy camping! Haha.
Old 08-26-2018, 04:41 PM   #52
2018 25' Flying Cloud
2018 22' Sport
Montara , California
Congratulations! These huge purchases feel like they should come with no problems, but alas, there are things that need fixing.
Screws. The closet door latch did’t want to stay screwed in after a few trips. We bought stainless steel screws from a local hardware in just a teeny bit wider/longer and replaced both screws. Perfect. Plus, you can use them in other areas.
Front Door. Why the front door isn’t checked more carefully is beyond me. If you have a hard time opening or closing the door, go get it fixed! You are in warranty and a slight adjustement will take care of it. Don’t rip your arm off pulling the door open...or getting “locked” inside.
Take your key with you if you shut the door. Just ran into someone who’d locked themselves out because the door accidentally locked. They tell you this at the dealer and they mean it. Make it a rule.
TV. We were told it didn’t get surround sound. We didn’t watch much TV and then we just dealt with it. Movies were great.
Bathroom vent. Open the window. Sure you freeze your bum off in winter, but ok.
Biggest regret is no stove hood/ventilation. I set that darn smoke alarm off ALL THE TIME. Maybe you are vegan and don’t eat bacon. Maybe you can cook the bacon outside.
Lastly, when it’s time to turn that furnace on it’s a bear. That teensie dial on ours was hard as heck to pull on. After the first turn on, it was fine.
Good luck and enjoy it! We loved our Sport.
Coastalphoto is offline   Reply With Quote
Old 08-26-2018, 05:42 PM   #53
Cypress , Texas
I agree with RJJ. With my 2017 F150 and 25 twin, I find that 60 - 62 is really good and safe and it keeps the rpm below 2000. With the 36 gallon tank you can cover a lot of safe miles.0
Geojim is offline   Reply With Quote
Old 08-26-2018, 09:13 PM   #54
2018 27' International
Jacksonville , Arkansas
The few trailers I pulled, that became unstable above 55, had too little tongue weight. You may need to increase that, or put more cargo in the truck bed to add weight to the rear axle. Ideally, this could be done with adjustments to the WD hitch.
Deeno is offline   Reply With Quote
Old 08-26-2018, 09:53 PM   #55
lwp99's Avatar
Gold Canyon , Arizona
Been towing for about 400 miles today with no problems. Gets shaky if I creep above 65 with wine and traffic so I try to keep it 65 and below.
I have noticed lots of sawdust in front of fridge after towing,is that common? I will try and post a picture later.
You should save the wine until your destination.
- Larry
lwp99 is offline   Reply With Quote
Old 08-27-2018, 03:22 AM   #56
2016 23' International
1991 29' Excella
Chesapeake , Virginia
Aacreek
Welcome to the airstream lifestyle.
You rig looks very sharp.
I use a Tundra with my 23 fb narrowbody
and try to stay at 62 mph.
It seems safer to smell the roses and watch people pull away from you traveling down the road. Your hitch set up may need to be fine tuned by an expert. I believe mine could be dialed in just a tad better.
I use an e2 hitch.
Enjoy your days adventure then hop in the airstream for a hot shower,cuddling luxury and a good night sleep!
Tom
Muriel 1 is offline   Reply With Quote
22FB Sport :: 2012 Airstream Sport Bonita Airstream Registry Discussions 0 03-29-2017 02:23 PM
First AS, thoughts on this 22FB Sport Maddmike 2005 and newer - Bambi all models 10 04-19-2016 01:16 PM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
bad day airstreaming beats good day a power company part 2 john hd Off Topic Forum 9 02-13-2004 08:12 AM
bad day airstreaming beats good day at power company! john hd Off Topic Forum 5 01-29-2004 04:04 PM
