Old 08-19-2018, 06:40 PM   #15
Portland , Texas
Been towing for about 400 miles today with no problems. Gets shaky if I creep above 65 with wine and traffic so I try to keep it 65 and below.
I have noticed lots of sawdust in front of fridge after towing,is that common? I will try and post a picture later.
aacreek is offline   Reply With Quote
Old 08-19-2018, 06:43 PM   #16
JJTX's Avatar
2018 19' Flying Cloud
South of Austin , Texas
Originally Posted by RJJ View Post
Take your speed as needed. I travel roads that have higher limits, but, I stay to the right and rarely exceed 62 mph. It's ok with me if others overtake and pass me... I prefer that to those who will tailgate. They're the ones who scare me. 😲 😱
Safe and happy travels to you. 😊
^^ this.
Being in a hurry with an RV will, eventually come back to bite you, and it wont be cheap.
2018 Bambi 19
www.usairc.org
JJTX is offline   Reply With Quote
Old 08-19-2018, 06:57 PM   #17
2011 28' Flying Cloud
Orillia , Ontario
Hitch
I agree with towing to fast but I would question your hitch set up, also tires on tow vehicle. There are many factors not just speed.
When hitch installed was a new hole drilled so ball would go in closer to axle?
Was height of ball measured correct and is the ball angle correct?
So not always speed
George
Rust is offline   Reply With Quote
Old 08-19-2018, 07:51 PM   #18
2019 25' International
Washington , Washington, D.C.
I wonder why a stove vent wasn't built in to your model.
PatLee is offline   Reply With Quote
Old 08-19-2018, 08:04 PM   #19
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Go to the Cat Scales and weigh you combination before your next trip and see if you are transferring about i/3 the tongue weight on to each TV axle and 1/3 back to the TT axle(s). If not, adjust your spring bar tension to achieve approximately that distribution.
Then there is always the Hensley Cub that is designed for smaller trailers. That hitch design eliminates sway before it can develop. No white knuckles.
guskmg
Old 08-20-2018, 04:05 AM   #20
2018 22' Sport
Fort Myers , Florida
Our adapter was missing. That is why the speakers did not carry the sound. Bought one on amazon and attached it behind the Jvc.
Lilyfielding is offline   Reply With Quote
Old 08-20-2018, 06:25 AM   #21
2018 22' Sport
Allentown , Pennsylvania
Same Issues
We just bought the exact same AS and really love it but I too noticed there is no way to play the TV through the overhead speakers. AS really missed an important mark with this. With the AC running you cannot hear the TV if you are in bed.
Has anyone had an issue with the Omni Antenna? We cannot receive ANYTHING with ours. I took it back to Colonial RV in NJ and they were not able to fix it. We were out a few weeks ago to a site that I know we should have received signals and got nothing so a trip to Walmart and $10 bucks later I bought a cheap set of Rabbit Ears. Instantly we received 22 stations. Any suggestions anyone?
thanks!!
The Flamingo is offline   Reply With Quote
Old 08-20-2018, 07:30 AM   #22
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Unless the flutter is caused by a tire or wheel out of balance, I’m still thinking it may be spoiled air in the back of the Tacoma as it pile up against the gate. Try opening the rear bed gate of the truck and taking the AS out on a highway and drive 70 mph. See what happens. If it works as I imagine, a tonneau cover or bed cap would be in order.
Airstream’s are so aerodynamic I cannot imagine any speed where it does not pull smoothly barring a wheel/tire out of balance or a problem induced by the TV. I agree with those who say to weigh the entire setup, but only as a last resort.
Did your dealer go over the complete cinch-up of the WD system and explain that when it is correct, the TV and AS will appear as a single, straight line from the side view? Did they verify the load capacity of the Tacoma? Just trying to think why your Airstream 22 would pull any different than mine. There are times when I exceed the speed limit (not bragging) to pass a truck and realize I’m towing. I feel absolute no sway or flutter.
When you solve the mystery, please share the solution so we can learn. Good luck.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign K5FT
Msherw is offline   Reply With Quote
Old 08-21-2018, 07:01 AM   #23
Portland , Texas
Here are pictures of my setup as we drove it home. Unfortunately we could not find a good deal in Texas so we purchased at Chilhowee in Tennessee.
We are getting a bed cover regardless for secure storage. Maybe that will help. Towing on the way home was fine, not too many issues with sway. I am not crazy about the eaz lift with the sway bar. I really liked the Andersen we had with our previous trailer.
Also is a picture of some items that “shook” out onto the floor. I am hoping they were just left behind during construction and not anything important.
Thanks for all the input.
ID:	320451Click image for larger version
ID:	320452Click image for larger version
ID:	320453Click image for larger version
Old 08-21-2018, 07:13 AM   #24
pastorwug's Avatar
2018 16' Sport
SANTA MARIA , California
Originally Posted by aacreek View Post
. . . Gets shaky if I creep above 65 with wine and traffic so I try to keep it 65 and below.
Wine may be the reason your shaking anyways?
2018 Sport 16
Haven't arrived but well on our way!
KK6YFG
Golden Central Coast of California
pastorwug is offline   Reply With Quote
Old 08-21-2018, 07:47 AM   #25
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I use an Eaz-Lift that was set up by Can-Am in London ON and I am very pleased with both the WD and the anti-sway performance. There are many factors that can contribute to trailer sway, starting with a properly tuned lash up.
From your photos it appears to me that the trailer is sitting very nose high. This could be because your ball mount is not low enough, even though it is in the last set of holes on the drop. Perhaps a longer drop would help. This is important to get the WD tune in. The low tail of the trailer will be more susceptible to sway.
The hitch head does not seem to be tilted down towards the aft of the hitch. The Eaz-lift uses washers that change this angle with the adjustment of the bolt.
I also don't see any anti-sway bars. Perhaps you only have one, mounted on the curb side. Two of the anti-sway bars would also be better than just one. They need to be tightened very tightly when going faster and in windy conditions.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 08-21-2018, 10:56 AM   #26
keweenawbee's Avatar
2018 22' Sport
eden prairie , Minnesota
Attachment 320451Attachment 320452Attachment 320453Attachment 320454
Those are the Wago lever nuts. That may have something to do with your stereo problem and the usb outlet in that white enclosure box up there. I use those Wago lever nuts a lot. Did not know or ever think about their being subject to vibration. They sure are handy time savers though.
2018 Sport 22fb
Ford Transit 250 Quigley 4x4
Gitchee Gumee on the Keweenaw Peninsula
keweenawbee is offline   Reply With Quote
Old 08-21-2018, 12:28 PM   #27
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
[QUOTE=aacreek;2145654]Here are pictures of my setup as we drove it home. Unfortunately we could not find a good deal in Texas so we purchased at Chilhowee in Tennessee.
I really agree with Keweenawbee, Tacoma looks a little 'up' in the nose which means the hitch may need to be lowered prior to hitching so the equalizer bars will bring the chassis into a straight line. On a second thought, can you go back to the dealer and tell them the problem and let them correct it? You may be to far away but I thought I would mention it.
I really thought most all AS dealers were pushing Equal-I-Zer since they have been an AS joint venture much like Zip Dee since way back. In fact, E-I-Z features an AS on it's splash net page. I don't want to talk too much about the WD anti sway subject too much here - reams have been written on the forum and everyone has their personal opinion - just like...well you know.
Ok, Im sure the WD hitch you have can be successfully adjusted to lower the Tac nose and the AS tail some. Have you tried to drive with the tail gate down yet? That may tell you a lot. Also, you may want to test a heavy tool box or ice chest in the rear bathroom for the trip home. Don't do it forever, just a test of the setup and sway.
I'm pretty sure the Tac/4Runner have almost identical curb and towing weights but it may not be so. Back to finding a good dealer to set up the WD. Will be following your progress.
Will you be coming back into Texas via Texarkana? Hwy 82 is about the worst road on our recent 3200 mile trip to Michigan. Just a warning.
Mike
M!ke
Old 08-21-2018, 12:34 PM   #28
San Diego , California
Did you turn the radio / tuner / cd “on” and set it to AUX. adjust the volume upward... then it plays they the speakers
Marchitect is offline   Reply With Quote
22FB Sport :: 2012 Airstream Sport Bonita Airstream Registry Discussions 0 03-29-2017 02:23 PM
First AS, thoughts on this 22FB Sport Maddmike 2005 and newer - Bambi all models 10 04-19-2016 01:16 PM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
bad day airstreaming beats good day a power company part 2 john hd Off Topic Forum 9 02-13-2004 08:12 AM
bad day airstreaming beats good day at power company! john hd Off Topic Forum 5 01-29-2004 04:04 PM
