Old 07-11-2016, 11:37 AM   #1
2015 16' Sport
Jacksonville , Florida
Entry door for new Bambi has a window
Can I replace my 2015 Bambi entry door with the new? Would like to be able to see out the door when it's closed. I put a call in to Airstream with this question but no return call as of yet.
Mageliza is offline   Reply With Quote
Old 07-11-2016, 12:20 PM   #2
2011 27 FB International
Vancouver , British Columbia
Can you actually see out the door windows now? My 2011 door is highly frosted. If there is a lot of light outside, you can see a shape if someone is there, otherwise not really anything.
mixedpuppy is offline   Reply With Quote
Old 07-11-2016, 04:07 PM   #3
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
I would like to add a window to ours just to get more light inside. Not sure what is involved but suppose the factory could do it for a (considerable) price.
2015 Airstream Bambi Sport 16J
Past Travel Trailers:
*1992 Dutchmen 30' Bunk
*2003 Jayco Designer Series 32' Rear Living
*2015 T@B Sofitel S (exchanged after 3 days for Bambi)
remphoto is offline   Reply With Quote
Old 08-15-2016, 12:56 PM   #4
stumppyv's Avatar
2017 25' Flying Cloud
Placitas , New Mexico
We just purchased our 2017 Bambi 16 Sport with the door window. We looked at a lightly used 2016 Bambi 16 Sport without the window. The dealer estimated 5K !!! for a new door as they would not install a window in the 2016 door nor would the remaining warranty remain valid.
stumppyv is offline   Reply With Quote
Old 08-15-2016, 01:04 PM   #5
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
No, you can't see out the door window as it is highly frosted.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 08-17-2016, 04:12 PM   #6
Boxite's Avatar
2008 22' Sport
The Airstream doors are a highly, labor-intensive install due to the need for careful fitting/fitment. The factory claims to spend an entire day on each door just for that work.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-17-2016, 06:08 PM   #7
1973 31' Sovereign
Minneapolis , Minnesota
Holy Sh!t. That is some money.
fairtheewell is offline   Reply With Quote
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
New Entry Door Hot Rod Doors & Locks 1 03-11-2011 06:12 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
Entry Door 2006 75th LE Custom Bambi Kevbo10 Doors & Locks 1 03-24-2006 08:22 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
