Old 10-07-2017, 04:58 AM   #1
Seattle206's Avatar
2018 22' Sport
Bellevue , Washington
Enclosed Aluminum Insulated Heated Underbelly on 2018 Sport 22
The product description on our 2018 Sport 22 States it has “Enclosed Aluminum Insulated Heated Underbelly”. Anyone have an idea what area is specifically heated, and is this simply a comfort feature or does this mean if we run the furnace in winter we have any added protection against freeze up of water lines?
Seattle206 is offline   Reply With Quote
Old 10-07-2017, 06:14 PM   #2
formerly Xipper
2011 22' Sport
Portland , Oregon
All of the water lines are above the floor. The main thing is that the furnace is ducted to also warm your fresh, black, and gray water tanks to reduce the chance that they freeze. I don’t know what temperature that actually good to, you’d have to look around the forums to find more info about cold weather camping. There are definitely those that do it though, had may require creativity to get below zero.
SilverHouseDreams is online now   Reply With Quote
Old 10-24-2017, 02:25 PM   #3
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
I took the wardrobe floor cover up to install a 12vdc power plug in the closet. I examined the area and indeed the water lines all exist above the lower subfloor and the furnace ducts pass over and around (but not through) the grey and black tanks. Didn't see if they also warm the fresh tanks but figure they do. And the shiny belly pan is visible as well. There is a lot built in redundancy for this AS.
If you store your AS in an enclosed bldg. I wouldn't bother running the furnace. Outside in freezing wx? Well I would still drain as much water as possible and set the temp on the lower range as insurance. But the furnace will suck LP like a Slurpee.
Last thought - since the pipes are above the subfloor - a ceramic heater left on inside may do the trick but I would monitor temps periodically JIC and still drain all lower pipes.
2018 Sport 22FB / Toyota 4Runner V6
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign NO5Y
Msherw is offline   Reply With Quote
2018 Jeep Eco-Diesel VS 2018 Expedition? Barretta2 Tow Vehicles 57 03-10-2018 03:39 PM
Valve repair access with enclosed tanks Jammer Waste Systems, Tanks & Totes 0 06-01-2014 06:57 AM
enclosed AC inside RV RhinoWW Furnaces, Heaters, Fireplaces & Air Conditioning 9 04-22-2014 05:40 AM
2014 Airstream International Serenity 25BWB New - Heated/Insulated Tanks & More! eBay Watch Airstreams on eBay 0 11-19-2013 02:10 PM
towing enclosed racecar trailer fangthorpe Mechanics Corner - Engines, Transmission & More... 1 06-30-2002 04:45 PM
