Old 03-27-2014, 02:24 PM   #1
2004 19' Bambi
Dayton , Wyoming
Electrical question
I have an '05 19' Bambi stored for the winter here. I have the power plugged and all the lights work, but when I plug something into an outlet, nothing. Is there a gfi somewhere I'm missing? I've tried the breaker panel. I'm sure it's something pretty basic, and being new at this it wouldn't surprise me. Thanks for any help.
Dave McDouga is offline   Reply With Quote
Old 03-27-2014, 02:48 PM   #2
1986 31' Sovereign
Miami , Florida
Lights are 12 volt from the converter/battery. You apparently have no 120 volt power. In mine, I would start with the outlet I'm plugged into, then the main breaker, then the breakers on the branch circuits.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-27-2014, 02:52 PM   #3
1986 31' Sovereign
Miami , Florida
Since you have checked the breakers, then it has to be something relatively simple - power cord, maybe? Mine is lots older than yours so there is nothing between the male plug on the power cord and the breaker panel. Does yours have a female plug on the unit itself? Cruddy contacts? Kind of a head scratcher...
Mike
Young, lovely bride
Old 03-27-2014, 03:21 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
When you loose power you start at the source and work your way to the item in question. Take a voltmeter or some other 110 item and check for power at the city connection. If you have power there plug the trailer in and go to the beaker panel and test for power on the input side of the breakers. If there is power there test the output side of each breaker. You do this until you find a spot without power. If you find the spot without power you repair from that point back to the last point you had power. It may be as simple as a popped breaker or a hard as a broken wire in the wall. But there is no simple way to bypass this procedure.
2004 Excursion 4x4
Old 03-27-2014, 05:22 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Check the bathroom for a GFCI and reset.
Also if you have a charging inverter the inverter will have circuit breakers on the 120V output.
Garry
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
Sovereign electrical update / question krowsea Electrical - Systems, Generators, Batteries & Solar 4 09-06-2004 08:27 PM
Electrical Question Alex Electrical - Systems, Generators, Batteries & Solar 5 01-10-2004 10:12 PM
Newbie with an electrical question Whistling_Gypsy Electrical - Systems, Generators, Batteries & Solar 3 12-28-2003 06:24 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
