Old 06-18-2019, 05:30 PM   #1
2019 22' Sport
Malibu , California
Dual 6 volt fit for 2019 22
Finally found box ($69, EBay) that fits on rails with dual Sams golf cart batteries, end to end. Have to buy new straps but screwed the box down. My bride says ďwhy not silver or blackĒ. Canít win but with PD 4655 upgrade (DIY) we are good for camping.
https://www.ebay.com/itm/GCE-G-Dual-...-/282981414026
ID:	343721   Click image for larger version
Garfish is offline   Reply With Quote
Old 06-18-2019, 09:28 PM   #2
2019 22' Sport
High River , Alberta
Looks great! Something Iíll consider when the original battery gets tired.
AlbertF is offline   Reply With Quote
Old 06-18-2019, 10:48 PM   #3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
You can easily give her Silver OR Black....either comes in a can for $5 or so. In all seriousness...I'd take it off and spray it, either gloss black or silver metallic. Would look so much nicer!
pcskier is offline   Reply With Quote
Old 06-19-2019, 02:50 PM   #4
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
Your Gfriend is correct. I believe there is an extension fog your existing box...
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Old 06-19-2019, 09:00 PM   #5
2019 22' Sport
Waynesville , Missouri
I really like your box. I was planning on doing something similar. What company made the box? I have a 2019 22í Sport FB. On that front rail thereís a manufacturer installed plug-in port for a solar panel. Did you have one too? If so, where did you move it to? Once I figure out where to move that port, Iíll do about the same thing you did with the twin batteries. Thanks for the ideas!!!
DAVSCH is offline   Reply With Quote
Old 06-19-2019, 10:31 PM   #6
2019 22' Sport
Malibu , California
Made in Canada and link to it on eBay is on my original post. My 22 did not come with Zamp connector so no issue. Never used the one on my first AS, a 16. I use alligator clips to battery with Renogy portable solar
Old 06-20-2019, 06:54 AM   #7
2019 22' Sport
There isnít much to the Zamp solar connector. If itís in the way and you can find a better spot for it, replace it with a flat two pole connector. Using the ground and first wire of a flat four trailer light connector will work too. You can connect it to one of the batteries in a way that you can reach it and plug in the solar panel.
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
