Old 01-20-2017, 08:01 AM   #1
2019 25' Flying Cloud
2018 23' Flying Cloud
NC , SC, GA, FL
Dometic 3-way Fridge in 22 Sport
Has anyone used their Dometic 3-way Fridge on DC power ? Mine works fine on propane and AC, but when it is selected to run from DC it blows the 3 amp fuse. I have it at the dealer and they are telling me it is blowing the fuse on DC when the trailer is connected to shore power. Can this be correct ? Just want to see if anyone else had this type of issue. Thanks.
Xplore is offline   Reply With Quote
Old 01-21-2017, 11:51 AM   #2
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
If you are on shore power, shouldn't it be on electric, not DC?
Am I missing something.
It is my understanding that DC would be chosen if you were running on battery only and did not want to run on propane.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 01-21-2017, 12:29 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Replace the fuse.
Unplug the trailer and see if it works
3 amps would not be enough to power a heating element.
It could be a control board problem.
Old 01-22-2017, 02:28 AM   #4
NC , SC, GA, FL
Originally Posted by TG Twinkie View Post
Replace the fuse.
I'm having the dealer service come out and take a look at it. Something is def. not right.
I think the 22 sport is the only model that comes with the the 3 way fridge. You wouldn't want to do an initial cool down using the battery setting, but we really enjoy having the fridge on when traveling to the next camp site without using propane.
Old 01-22-2017, 02:51 PM   #5
1996 25' Excella
Tillsonburg , Ontario
We never found the three way workable on12VDC. There just never seemed to be enough voltage at the trailer when under way, which is the reason the 12VDC is provided. The heating element consumes quite a few amps so it is not really an option when Parked.
Non-the-less you have some sort of problem not related to voltage since the heating element is resistive and amps go down if voltage is low, so that would not blow a fuse. I get the impression from your post, the fuse blows when switched to DC...immediately? Then is is a short some where in the heating element circuit.
JCW
JCWDCW is offline   Reply With Quote
Old 01-22-2017, 03:30 PM   #6
2015 22' FB Sport
Wethersfield , Connecticut
We have used the D.C., AC and the propane on our fridge (2015 22FB Sport) with no problem. The D.C. Does use a lot of power and will deplete the battery in a couple of hours. I have also used the D.C. While towing with no issue. Since the D.C. Is completely separate from the AC there should be no reason to blow the fuse when plugged to shore power and using the DC mode on the fridge.
TinkersToy is offline   Reply With Quote
Old 01-22-2017, 10:26 PM   #7
Classy Roscoe
Jekerrville's Avatar
1969 31' Sovereign
Kerrville , Texas
Be certain that the fuse "type" is correct! There are several types for a particular current requirement.
Standard auto fuses are usually quick blow. That is as soon as, in your case, 3 amps is reached pop!
But when the DC circuit engages the peak in-rush of current could be above the 3 amp level if only for a few miliseconds. A slow blow fuse would withstand the in-rush but still protect the fridge and the trailer.
Double check the spec for the fuse in the owners manual. Somebody may have used the wrong fuse.
Stay cool.
Jekerrville is offline   Reply With Quote
Old 01-24-2017, 04:27 AM   #8
NC , SC, GA, FL
Thanks for the input guys. Airstream is sending a tech out. I'll post up what the he finds.
Old 01-31-2017, 10:13 AM   #9
Boxite's Avatar
2008 22' Sport
JCWDCW, the amps do not go down when the voltage drops. The amps goes UP when the voltage drops. (which may explain why the fuse blows... insufficient voltage at the refer.... fuses react to Amps.)
Volts times Amps equals Watts. VA=W
So if volts go down, amps must increase.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 02-01-2017, 12:26 PM   #10
1996 25' Excella
Your formula is correct for a reactive load like a Motor. Fridge heater is resistive. To control power on a resistive load you reduce voltage. Remember how the flashlight gets dimmer as the battery wears down.
OHM's Law V=IR thus I ( which is what the fuse controls) = V/R...lower V lower amps
JCW
Sport 22FB - Dometic 3-way Fridge - Storage Adventure.AS 2005 and newer - Bambi all models 6 07-24-2017 06:09 PM
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
Dometic 2 Way Fridge snakecharmer Airstream Classifieds 0 01-08-2014 02:11 PM
2-way vs. 3-way Dometic loriday Refrigerators 12 08-15-2010 09:21 PM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
