Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi > 2005 - Bambi all models
Old 10-13-2005, 12:06 PM   #1
DreamStream
DreamStream's Avatar
Profile:  2005 19' Safari
West Palm Beach , Florida
Design Flaw Rust
Starting to rust quite a bit on the '05 Bambi where the can that covers the propane tanks sits down on the frame. Is this a warranty issue the dealer should cover or considered normal maintenance. Looks like they would have placed a piece of rubber or something there instead of letting the metal rub against metal.
Still loving our 2005 Bambi with the front sofa!!!!!!!!!!!!!!!!!!!!!!
Stephen & Miriam
2005 Bambi Safari 19 LS with Sofa
2006 Harley-Davidson Road King Custom
2005 Dodge Ram 3500 CTD QuadCab SRW Long Bed
Sir Wooferman Wellington, Cock-a-poo Watch Pup
DreamStream is offline   Reply With Quote
Old 10-13-2005, 12:21 PM   #2
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I had the same thing start, and put some rubber feet to stop the contact...seemed to stop it dead in it's track....I also Walbernize the "A" frame too.
Old 10-13-2005, 05:19 PM   #3
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
i believe the owners manual states you should paint the A frame once a year.
i've had to paint mine once since 1992, so take it for what it is worth...
john
you call them ferrets, i call them weasels.
Old 10-13-2005, 05:33 PM   #4
SilverRanger
SilverRanger's Avatar
1968 24' Tradewind
Milton , Delaware
I noticed the same on mine. I also posted in another thread that I found several places where the cover was rubbing against the tanks. A few adjustments, and some well placed velcro pads solved the problem. I regard Velcro as highly as some people regard duct tape, and keep lots of both in the Bambi.
SilverRanger is offline   Reply With Quote
Old 11-02-2005, 11:55 AM   #5
SilverRanger
1968 24' Tradewind
Milton , Delaware
Screws
I just changed out the rusty screws that hold the clearance light lenses with new stainless ones. The replacements I used were 6-32 x 5/8". They were a tiny bit big, but after the first two or three rotations they threaded on very nicely. The gaskets from the original screws fit perfectly. I was surprised at the amount of condensation under all of the lenses.
Total cost: $1.10
Not exactly a major upgrade, but I sure feel better.
Old 11-02-2005, 03:06 PM   #6
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We saw some potential rub points also. I buy some foam that has a sticky side. I place the foam at those points where a rub can occur. One other point that came to mind was the back of the electic jack and the gas bottle cover. A point that you can hit when you pull off the cover to get to the bottles.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
Christmas Design from CJ CJsTs The Vendor's Forum 12 12-14-2003 05:02 PM
Design feature or possible Nightmare?? Jason1101 General Repair Forum 5 01-13-2003 04:04 PM
latest design concepts 53flyingcloud Our Community 3 06-29-2002 10:33 AM
Rust on Frig. niftypkg Refrigerators 0 05-20-2002 06:43 PM
