Old 09-24-2013, 09:57 PM   #1
Chpstar1's Avatar
2013 19' Flying Cloud
Modesto , California
Question Connect two TVs to winegard antenna
Hi, I finally went for it and purchased a 2013 19 Flyingcloud, can someone please tell me how can I connect a second tv to the antenna or do I need to get a different antenna?
Chpstar1 is offline   Reply With Quote
Old 09-24-2013, 10:27 PM   #2
1988 25' Excella
Trumbull , Connecticut
2 TVs 1 Antenna
Hello CHPStar1. Just go to Radio Shack and buy a coax splitter. It will have 1 input and 2 outputs. Some splitters will have more than 2 outputs but you only need 2. Put the coax from the antenna to the splitter input and connect the 2 TVs to the splitter outputs.
Thats all there is to it
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 09-24-2013, 10:30 PM   #3
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
I think your Winegard has a signal amplifier on it. You could put a splitter on the antenna cable and add another amplifier on the cable to the 2nd TV. Or you could try a splitter after the existing amplifier and run a cable to your 2nd TV. But every splitter will decrease your signal strength.
arktos55343 is offline   Reply With Quote
Old 09-25-2013, 06:01 AM   #4
dznf0g's Avatar
Oswego , Illinois
Check the back of the amplifier....I think most have cable fittings for 2 TVs.
http://dutchmen.com/image/data/docum...ts/2451808.pdf
Set one is on the front of the plate and set 2 is on the back.
-Rich-
Old 09-25-2013, 10:42 AM   #5
Chpstar1's Avatar
Thx for your tips, I will check the back of the amplifier first, then go from there, thx again to all of you.
