06-07-2014, 06:53 PM
Retired.
, At Large
I will probably be crucified for this, but I bought a 100 watt plug in inverter from Flying J for $10, and plugged our tv into it. Most LCD and LED televisions draw much less than 50 watts.
06-07-2014, 06:55 PM
1974 Argosy 20
Kooskia
, Idaho
Either of those would probably work, but are not sine wave inverters. Some, but not all televisions are sensitive to the waveform produced by the "modified sine wave" ones you show in your post. No way to tell about your Sansui.
For a good selection of sine wave inverters, take a look at this site. They are a pretty good supplier of inverters at reasonable prices.
Power Inverters | DonRowe.com
06-07-2014, 07:57 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Home Depot chain wide is closing out a cigarette lighter inverter. It's only good for 100 watts, but u have powered lots if chargers, power supplies, and a few flat screen TVs with it. Now $15 in the dept with av cables and those type gadgets.
06-07-2014, 08:03 PM
Oregon city
, Oregon
Just got one, it works! Thanks everyone
06-07-2014, 09:33 PM
2005 28' Safari S/O
Paradise
I use a 140 continuous watt cigarette lighter inverter from Radio Shack. I just plug a power bar into it and run my tv, bluray and amplified speakers w/ small subwoofer from it and it works fine. Been using it this way for 7 years, although I just replaced my older tv with a newer LED one...bigger screen, and less power draw.
Steve
"THE OLDER I GET, THE BETTER I WAS"
06-08-2014, 06:37 AM
Retired.
, At Large
One what? Which one did you end up with? The suspense is killing us! Okay, maybe not, but we're still curious.
06-08-2014, 10:27 AM
Oregon city
, Oregon
The 175w inverter in my link works.
07-14-2016, 04:25 PM
2019 20' Flying Cloud
Eau Claire
, Wisconsin
I use a 100 watt inverter (no fan for less watt draw). The TV in the 16' Bambi draws 26 watts so I feel safe watching TV or a DVD. I have to run a cable from the battery to the cig lighter that the inverter plugs into. Wish they would have put a cig lighter in there near the TV. Good luck~!
07-14-2016, 04:32 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
The TV in our Sport 22FB uses 19v to power it. There is a transformer with it that steps down from the AC outlet to 19v DC. However, you can purchase a 12v to 19v transformer that will run directly from DC. I think that this may be more efficient than using an inverter and then a transformer.
Ray B.
07-14-2016, 06:43 PM
1979 23' Safari
Wayland
, New York
Watch the power of the inverter. If you're going to be plugging into the 12vdc plug that's incorporated into the tv amplifier, it's rated to 8 amps of 12vdc. That's 96 watts, so I wouldn't get anything larger than 100watt inverter to plug into it.
The tv probably used about 30 watts if it's a 19" model.
07-29-2016, 12:43 PM
2016 22' Sport
Sandpoint
, Idaho
$12.70 got us a 12volt to 19volt converter. Wired it in replacing the small 120VAC to 19volt brick. Works great.
08-13-2016, 11:01 AM
2016 16' Sport
Port Angeles
Yachthalo where did you get the converter?
08-14-2016, 10:18 AM
2016 22' Sport
Sandpoint
, Idaho
Amazon,
[URL="uxcell® Weatherproof Power Supply Module Converter Regulator Transformer BOOSTER DC 12V (9V~18V) Step-Up to DC 19V 5A 95W FOR NOTEBOOK"]
08-14-2016, 10:25 AM
2012 25' FB Flying Cloud
Celina
, Ohio
We use the same thing and have had no problems
Gary
