Old 09-24-2015, 12:38 AM   #1
2016 16' Sport
Santa Barbara , California
Can't get the front window open on 2016 Bambi
Does anyone have an idea how to get the glass unstuck from the gasket on the front window? There is a sticker that says it may get stuck from hot weather but I can't get it to open. Have opened the rock guard and opened the two holders on the inside. I'm totally flummoxed. Am I missing something. This Bambi is brand new, just picked it up,yesterday.
Thanks for the help
SB Steve is offline   Reply With Quote
Old 09-24-2015, 05:11 AM   #2
'15 Flying Loud 20' Bambi
renderit's Avatar
2014 16' Sport
small city outside a big one , south of some, north of some
I always have to do it (at least at the start) from the outside. That is both on our 2014 16' and our newer 20'. The seal sticks hard enough there's no way you can get it from inside. The geometry of the arms makes starting them nearly impossible. Entirely normal by the way.
renderit is offline   Reply With Quote
Old 09-24-2015, 05:18 AM   #3
Gainesville , Florida
Better to have it stick than be too loose and leak. Use a credit card on the outside?
Old 09-24-2015, 05:26 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I use a plastic pancake flapper, or you can use a plastic pie knife. Start toward the top, near one of the corners, and gently push it between the glass and gasket. work your way around the window, until the window becomes unstuck.
Old 09-24-2015, 06:01 AM   #5
Long Island , New York
My new FC20 is the same. Use a plastic small tool CC etc. to lift lower corners of glass from the outside. Soon the rubber gasket will have a very thin film of dust on it which will prevent sticking down the road. Not necessary to add a lubricant/release agent IMO if you are patient. This is a natural process of the rubber gasket curing a bit more when exposed to air and dust.
Old 09-24-2015, 06:06 AM   #6
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Slice a credit card between the window and gasket. Sun etc heats it up and they stick.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 09-24-2015, 07:57 AM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I wipe the seals with silicone spayed onto a paper towel. With time and age the sticking becomes less. When the trailer is new, apply the silicone more frequently.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-24-2015, 10:45 AM   #8
2015 25' FB Flying Cloud
Huntley , Illinois
ditto. use a credit card almost every time. carefully and works like a charm. we silicone also. had 2 new units and did with both. not an issue
cegardner is offline   Reply With Quote
Old 09-24-2015, 10:52 AM   #9
2016 23' Flying Cloud
leavenworth , Washington
I used a plastic knife ....pry easily and it will open from the outside
woodguy2 is offline   Reply With Quote
Old 09-24-2015, 10:53 AM   #10
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
In my mind that window and it's inside levers and catches are a pretty poor design and it's always a pain.
That being said plastic bicycle tire irons are pretty handy for this job. They are just good for lots of non marring type jobs. Had to take a door panel off the truck and they worked great there to pry and not scratch.
jtwind is offline   Reply With Quote
Old 09-24-2015, 10:55 AM   #11
gecko's Avatar
2009 28' International
Pacific Palisades , California
Use the credit card or fingernail trick on whichever of the two lower corners that looks least stuck, then get your finger underneath to "break" the seal and you're good to go!
gecko is offline   Reply With Quote
Old 09-24-2015, 11:01 AM   #12
casarodante's Avatar
2012 31' Classic
You can try these. I got them for all our windows.
Window Poppers
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 09-24-2015, 11:12 AM   #13
2016 25' Flying Cloud
Weatherby Lake , Missouri
I recommend wiping the rubber seals with 303 protectant after you get the window(s) open. It helps marginally with the initial sticking but has a nice matte finish (not as oily as some products) and provides the UV protection to the seal that will help prevent fading, cracking, and leaking in the future.
From Amazon: 303 (30313-CSR) Aerospace Protectant Trigger Sprayer, 32 Fl. oz.
Also available at the AS store for twice the price if you are so inclined.
SemperBadger is offline   Reply With Quote
Old 09-24-2015, 11:22 AM   #14
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
2nd 303. We too have the same problem. Most folks recommend the 303 .it's also available at Camping World.
This is the first time that I've heard that the issue decreases over time, good news!
DoublTrouble is offline   Reply With Quote
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 09:40 AM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 04:57 PM
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
Can't get door to open rbcarbo Doors & Locks 9 12-14-2014 06:11 PM
Main door lock broken..can't get open Becky B. Doors & Locks 12 08-05-2008 05:06 PM
