Old 09-30-2015, 04:36 AM   #43
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by cwf View Post
Since we are told 'no silicone' around your Airstream, I try to follow thru...
It's "no silicone sealant", not "no silicone". Acecetal silicone such as used in silicone caulk contains an acid that is corrosive to aluminum. Silicone lubricant does not.
Old 09-30-2015, 01:15 PM   #44
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Can't get the front window open on 2016 Bambi
Silicone caulk is a no no if you are attempting to use it as a sealing method. It has no adverse effects to the aluminum under my use. My method for applying it is to spray it on a paper towel and then wipe the gasket with the towel. You use a lot less and you don't have to worry about overspray or drips.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-01-2015, 07:24 PM   #45
2015 30' International
Granville , Ohio
It states in my Airstream manual to use 100% (spray) for the window seals. I'll keep using it and will count on Jack's experience for less sticking over time.
Mark
Mark
2015 International Sig
2015 Ford F-350 PowerStroke 6.7L
marcusmark is offline   Reply With Quote
Old 10-03-2015, 04:48 AM   #46
Long Island , New York
The Aerospace 303 towelettes from Amazon mentioned earlier worked great, and storage of the container is easy in my FC20 [small, light and non-liquid].
Thanks to Foiled Again for the "Pool Noodles Everywhere" headline -- sure got my attention and is a great idea. Multi-purpose too . . .
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 09:40 AM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 04:57 PM
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
Can't get door to open rbcarbo Doors & Locks 9 12-14-2014 06:11 PM
Main door lock broken..can't get open Becky B. Doors & Locks 12 08-05-2008 05:06 PM
