Old 09-25-2015, 09:47 AM   #29
2016 16' Sport
Santa Barbara , California
Originally Posted by Airstreamdlr View Post
The dealer should have lubed the seals. Use a credit card to break the window free and have your dealer lube the seals.
The dealer was less than great on this whole transaction. Too bad, I doubt I will see them again.
SB Steve is offline   Reply With Quote
Old 09-25-2015, 10:34 PM   #30
gecko's Avatar
2009 28' International
Pacific Palisades , California
Originally Posted by DoublTrouble View Post
M.
I hope it happens in my lifetime!
Howard do you have those poppers? Since we are new to Airstreams, I keep hitting my head on the opened windows. It was never an issue with my 5er!
The AS Windows offer three open positions. We never use the middle one--guaranteed to nail you every time!
Only use the bottom position, or the full open position. Unless you're very tall, you should be OK!
gecko is offline   Reply With Quote
Old 09-26-2015, 06:06 AM   #31
Long Island , New York
Yellow tennis balls make good forehead protectors on the windows open in the middle position. Just slit the ball so that it can be jammed onto the corners of the windows. Wearing a large-brimmed hat helps too . . .
Old 09-26-2015, 08:35 AM   #32
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Thanks for the warning on the middle window position, you may be exactly right on that.
Or maybe a wide brimmed hat with tennis ball glued all around the brim...... 😨
DoublTrouble is offline   Reply With Quote
Old 09-27-2015, 10:35 AM   #33
2015 25' FB Flying Cloud
Huntley , Illinois
we cannot get our large side windows in our 2025 FC 25. to stay open on the lowest setting in a slight breeze. we make sure the arms are set into the well net the well is so shallow the arms push out with the slightest breeze vans thoughts
cegardner is offline   Reply With Quote
Old 09-27-2015, 02:49 PM   #34
1979 23' Safari
Wayland , New York
Who was the dealer?
Old 09-27-2015, 03:45 PM   #35
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Same problem, especially the front large window. ???
Howard L. is offline   Reply With Quote
Old 09-28-2015, 10:38 AM   #36
2016 16' Sport
Originally Posted by HiJoeSilver View Post
Who was the dealer?
SkyRiverRV in Buellton, CA. Long story, but short result was unknowledgeable people and poor customer support on the part of the manager who stated "ask xxxxxx, I don't know anything about Airstream" and he was right, he didn't.
Old 09-28-2015, 10:59 AM   #37
2015 30' International
Granville , Ohio
Originally Posted by jcanavera View Post
I wipe the seals with silicone spayed onto a paper towel. With time and age the sticking becomes less. When the trailer is new, apply the silicone more frequently.
Jack
Jack, I used 100% silicone too but thinking maybe should've used auto "Sun of a Gun" since they still stick more than expected. Any history w Son of a Gun?
Mark
2015 International Sig
2015 Ford F-350 PowerStroke 6.7L
marcusmark is offline   Reply With Quote
Old 09-28-2015, 04:32 PM   #38
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
When you open, put the bars into 'detents' to keep in position. If they do not 'snap' down into the slot, that will let them pop closed..
Congrats on your advance delivery of a 2025!
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-29-2015, 02:58 AM   #39
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Can't get the front window open on 2016 Bambi
No. I use silicone on the seals of the slide out unit with good results. It seems like over time the seals tend to not stick as much. I'm not sure if it is tied to more use prevents the sticking, or whether the dust in the air actually coats them to a point where the won't stick as much. After about 2 years of use, the Windows stopped sticking on me. I can tell you positively that silicone will not harm the gaskets. Typically when the trailer was new, whenever I washed it which was before storing it after a trip, I'd silicone the windows. That pretty much assured me that they would pop open easily on the next trip.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-29-2015, 10:47 AM   #40
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Since we are told 'no silicone' around your Airstream, I try to follow thru..
At first, We thought it was a good idea, so I put the silicone then used a lot of 'talcum powder' (dust)... and that helped keep 'sticking' down. The Aerospace 303 works fine.
Channing
WBCCI# 30676
Old 09-29-2015, 10:07 PM   #41
Huntley , Illinois
thanks for your response. as I mentioned in the question we do seat the Windows into the wells. but the bottom wells are so shallow there is no snap in.
Old 09-29-2015, 11:12 PM   #42
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Head banging protection
Pool noodles Everywhere!
Awning Arms, window surrounds, and "eyebrows" on the front curved segment protectors (only while parked) to keep leaves, dirt, etc. from accumulating between the window guards and the window itself.
Pipe insulation segments will work as well but it is dull gray or black. Neon noodles are far more visible. Just slit and apply.
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 09:40 AM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 04:57 PM
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
Can't get door to open rbcarbo Doors & Locks 9 12-14-2014 06:11 PM
Main door lock broken..can't get open Becky B. Doors & Locks 12 08-05-2008 05:06 PM
