09-24-2015, 12:43 PM
#21
2016 25' Flying Cloud
Grove city
, Ohio
Originally Posted by SB Steve
Does anyone have an idea how to get the glass unstuck from the gasket on the front window? There is a sticker that says it may get stuck from hot weather but I can't get it to open. Have opened the rock guard and opened the two holders on the inside. I'm totally flummoxed. Am I missing something. This Bambi is brand new, just picked it up,yesterday.
Thanks for the help
The dealer should have lubed the seals. Use a credit card to break the window free and have your dealer lube the seals.
09-24-2015, 12:52 PM
#22
2015 30' Classic
Glen Mills
, Pennsylvania
Credit card as others stated. I just am in the habit of doing it each time.
09-24-2015, 01:23 PM
#23
1999 34' Excella
Hillsboro
303 had better success than the silicone... I cleaned the glass really really well first... then apply to both the glass and gasket..
But, to 'open', use the 'plastic' scraper or credit cards to 'pry' up a corner on left or right side .. apply 'pressure'... it may take a minute or so for the 'peal away' to start happening... no rush.. just ease the window up.. then clean and apply the 303... or silicone spray if that's all you have at the moment.
you can get 303 at West Marine.. or other fine Marine or RV dealers as it is recommended on Sunbrella fabrics!
Peace and Blessings..
Channing
WBCCI# 30676
09-24-2015, 01:37 PM
#24
2016 16' Sport
franklin
, Indiana
All those tips work well and amazing how easy it is after beating and pushing and cursing from the inside Just slide it along the outside edge.
09-24-2015, 02:42 PM
#25
2017 25' International
Carlsbad
But they never were stuck either...,😈
09-25-2015, 01:31 AM
#26
2012 30' Flying Cloud
San Antonio
Originally Posted by DoublTrouble
M.
I hope it happens in my lifetime!
Howard do you have those poppers? Since we are new to Airstreams, I keep hitting my head on the opened windows. It was never an issue with my 5er!
http://www.airforums.com/forums/f164...ml#post1358139
Here is the original thread for the window opener. Invented by "Uncle Bill".
09-25-2015, 04:55 AM
#27
'15 Flying Loud 20' Bambi
2014 16' Sport
2015 20' Flying Cloud
2021 25' Globetrotter
small city outside a big one
, south of most, north of some
I guess I'm lucky. On neither Airstream have I ever had to resort to using a card or other. Mine open when I use a little tug on each corner outside. I waxed the windows with Nu Finish, maybe that is why?
09-25-2015, 09:45 AM
#28
2016 16' Sport
Santa Barbara
Thanks everyone for your quick and helpful responses. I got the window open with a credit card. Nice trick. Got the 303 from a car parts place up the street. Should be good to go camping at my warehouse parking lot this PM to see of everything works before we head out into the vast unknown. Im sure there will be more questions.
09-25-2015, 09:47 AM
#29
2016 16' Sport
Santa Barbara
The dealer was less than great on this whole transaction. Too bad, I doubt I will see them again.
09-25-2015, 10:34 PM
#30
2009 28' International
Pacific Palisades
M.
The AS Windows offer three open positions. We never use the middle one--guaranteed to nail you every time!
Only use the bottom position, or the full open position. Unless you're very tall, you should be OK!
09-26-2015, 06:06 AM
#31
Sag Harbor
, New York
Yellow tennis balls make good forehead protectors on the windows open in the middle position. Just slit the ball so that it can be jammed onto the corners of the windows. Wearing a large-brimmed hat helps too . . .
09-26-2015, 08:35 AM
#32
Carlsbad
Thanks for the warning on the middle window position, you may be exactly right on that.
Or maybe a wide brimmed hat with tennis ball glued all around the brim...... 😨
09-27-2015, 10:35 AM
#33
2015 25' FB Flying Cloud
Huntley
we cannot get our large side windows in our 2025 FC 25. to stay open on the lowest setting in a slight breeze. we make sure the arms are set into the well net the well is so shallow the arms push out with the slightest breeze vans thoughts
09-27-2015, 02:49 PM
#34
1979 23' Safari
Wayland
, New York
Who was the dealer?
09-27-2015, 03:45 PM
#35
San Antonio
Same problem, especially the front large window. ???
09-28-2015, 10:38 AM
#36
2016 16' Sport
Santa Barbara
Originally Posted by HiJoeSilver
Who was the dealer?
SkyRiverRV in Buellton, CA. Long story, but short result was unknowledgeable people and poor customer support on the part of the manager who stated "ask xxxxxx, I don't know anything about Airstream" and he was right, he didn't.
09-28-2015, 10:59 AM
#37
Fulltimer Oldtimer
2015 30' International
Marietta
, Ohio
Originally Posted by jcanavera
I wipe the seals with silicone spayed onto a paper towel. With time and age the sticking becomes less. When the trailer is new, apply the silicone more frequently.
Jack
Jack, I used 100% silicone too but thinking maybe should've used auto "Sun of a Gun" since they still stick more than expected. Any history w Son of a Gun?
Mark
2015 International Sig
2015 Ford F-350 PowerStroke 6.7L
09-28-2015, 04:32 PM
#38
1999 34' Excella
Hillsboro
When you open, put the bars into 'detents' to keep in position. If they do not 'snap' down into the slot, that will let them pop closed..
Congrats on your advance delivery of a 2025!
Channing
WBCCI# 30676
09-29-2015, 02:58 AM
#39
2004 30' Classic Slideout
Fenton
, Missouri
Can't get the front window open on 2016 Bambi
No. I use silicone on the seals of the slide out unit with good results. It seems like over time the seals tend to not stick as much. I'm not sure if it is tied to more use prevents the sticking, or whether the dust in the air actually coats them to a point where the won't stick as much. After about 2 years of use, the Windows stopped sticking on me. I can tell you positively that silicone will not harm the gaskets. Typically when the trailer was new, whenever I washed it which was before storing it after a trip, I'd silicone the windows. That pretty much assured me that they would pop open easily on the next trip.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
09-29-2015, 10:47 AM
#40
1999 34' Excella
Hillsboro
Since we are told 'no silicone' around your Airstream, I try to follow thru..
At first, We thought it was a good idea, so I put the silicone then used a lot of 'talcum powder' (dust)... and that helped keep 'sticking' down. The Aerospace 303 works fine.
Channing
WBCCI# 30676
