Old 06-02-2014, 01:21 PM   #1
Oregon city , Oregon
Can I add second battery from different brand?
I want to add a second battery. The one already on my trailer is a interstate brand group 24 battery. It cost $105 in store. I heard costco sell their costco branded battery for $75. Can I get a the costco battery to work with interstate battery? Or it's better to have both battery the same brand?
Thanks!
Eresan is offline   Reply With Quote
Old 06-02-2014, 02:13 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
It's not only better to use batteries of the same manufacturer, they should also be of the exact same group size and preferably the same manufacture date and lot number.
Also, you should not place a new battery, even when exactly the same, into the battery bank if the original is generally in use over 30 days.
Batteries develop a charge profile and adding new to existing will almost guarantee that one or the other will not get properly charged.
Old 06-02-2014, 02:19 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I have heard it said and I think it is largely true that when batteries are in a bank, when one fails it hurts or even destroys the others.
I have mostly followed protocol here replacing all batteries in a bank at once, and then moving those that might still be good to single status in a different application.
I have at time judiciously replaced some batteries in a bank knowing I was taking a chance and gotten away with it.
Old 06-02-2014, 05:33 PM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Thanks!
Why don't you just get a GR29. I don't understand why you need two batteries.
Ahab is offline   Reply With Quote
Old 06-02-2014, 09:05 PM   #5
2003 25' Safari
Riverside , California
The internal resistance of the batteries may not match,this is where your charging issues can come from.With that being said,I can tell you that ram will only replace a failed battery not both under warranty.This tells me they are reasonably sure that the same size and brand are close enough to work together even if one is a bit older than the other
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 06-02-2014, 09:34 PM   #6
So, the conclusion is I have to get a more expensive interstate or 2 cheaper costco batteries...
Old 06-07-2014, 08:18 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I have have broken the rules and gotten away with it every time.
Old 06-08-2014, 04:38 PM   #8
Went costco stopper at their battery place, their battery guy says it doesn't matter what brand. It works it they are both group 24 batteries. Then I called dealer, their service guy told me the same thing. So I got a costco battery
Old 06-08-2014, 06:40 PM   #9
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I have heard that Costco batteries are made by Interstate. But it's only hearsay.
Is it possible to add a second Fantastic Fan? m.hony Roof Vents, Skylights & Fans 6 05-31-2013 02:38 AM
Add a second battery? dmac Electrical - Systems, Generators, Batteries & Solar 23 08-19-2009 11:20 PM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Different Looks on Different Computers COArgosy78 Forum Admin, News and Member Account Info 3 09-20-2003 02:38 PM
Second Battery w9det 1999 Safari 5 12-06-2002 06:42 PM
