Old 09-04-2017, 12:37 PM   #1
Perth , Ontario
Buying a 10 year old Airstream
Can someone tell me some of the more important questions and things to look for when looking at a 10 year old Airstream single axle. Do the torsion rubbers break down in this time frame?
RogerKidner is offline   Reply With Quote
Old 09-04-2017, 12:48 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
The torsion axles will likely be good.. do you know how much it was towed?
Jack up each side.. measure the deflection from load to no load..
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-04-2017, 12:49 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The torsion axles should be fine. Leaks and damage from leaks is the main thing, in my opinion. Holding tanks and dump valves. Dents. I think in terms of 25 to 30 years for the axles.
Bill M. is online now   Reply With Quote
Old 09-04-2017, 01:30 PM   #4
"Silver Shrek"
drairstream's Avatar
2000 27' Safari
Crestwood , Kentucky
Leaks! We bought a '99 safari. Minimal leaks. All mechanicals were good though we upgraded bearings brakes and wheels prior to any travel
Rot and mold are your big enemies.
Make sure Every system is proven to work! Shore power, 12 volt
Water both systems, furnace and AC. stove, microwave. Don't trust tires or brakes, bearings unless demonstrated to work.
We renovated ours for cosmetics only
Also line up your insurance before you pull it home. We have agreed value with progressive. Called them re our upgrades and they increased the value with no argument. Just asked me to keep the receipts.
drairstream is offline   Reply With Quote
Old 09-04-2017, 01:43 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
I would concider a 10 year old trailer still new. The big diference will be "who" owned it those ten years and how it was treated, maintained and stored.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 09-04-2017, 01:51 PM   #6
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Amen! It was the "who" with our 2005 Safari we bought last year, all age-related items were good or as-expected.
DaveMc is offline   Reply With Quote
Old 09-04-2017, 02:26 PM   #7
Long Island , New York
Welcome to the forum Roger!
In addition to the good advice so far, I would echo the caution on leaks, mold and mildew, and add smoking and pet odors into the olfactory considerations.
If possible when you look at the trailer, have it be sealed up tight for a few days, then go for an inspection, and be the first one inside.
Trust your nose!
If the AS has been well cared for, 10 years is no big deal. Of course a thorough run-through of all systems is a must. Water pipes full and under pressure, etc..
Good luck,
Peter
Old 09-04-2017, 03:29 PM   #8
2000 30' Excella
Toledo , Ohio
Look around the perimeter inside at the flooring take a moisture meter with you they are a cheap investment mine is a Sonin . Some have OSB sub floors if it stays wet it will rot quickly .Leaks will be the biggest hidden problem to look for .
Good luck hope you found what you are looking for .
woodfox45 is offline   Reply With Quote
Old 09-04-2017, 03:50 PM   #9
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Non-hidden "problems":
1) If the batteries are 10 years old, they need replacing
2) Tires - same thing
3) Brakes at least need to be checked, I would *assume* they need new pads unless proven otherwise.
4) Wheel bearings - same thing, assume they need replacing until shown otherwise.
5) You will have halogen lights. Plan on replacing them with LED's
6) Spend some quality time making sure the AC(s) work properly. Don't just do a quick check.
None of this part should be scary. Tires and batteries are a "use by 6 years" sort of thing and they have dates marked on them. Brakes and bearings can be checked by any competent mechanic.
Old 09-05-2017, 09:31 AM   #10
kdickinson's Avatar
1969 23' Safari
Taos , New Mexico
If it's been cared for properly and average use (a few trips per year) a 10-year old AS should just be getting broken in ... the key is was it cared for properly and is free of accidents, flooding, etc.. Cars and trailers end up for sale all over the country following a hurricane or tropical storm that were in high water and have been dried out and sent elsewhere to be sold. Just a couple things to think about ..
kdickinson is online now   Reply With Quote
Old 09-05-2017, 09:41 AM   #11
2019 25' International
Washington , Washington, D.C.
I second this! If it's had a good owner, a 10-year-young Airstream has had many of the quirks/problems fixed. Check state of sealant on the roof, the tread/age of tires and test appliances to ensure they work.
PatLee is online now   Reply With Quote
Old 09-05-2017, 04:42 PM   #12
2005 16' International CCD
LAFAYETTE , Colorado
Third owner on a 2006. Couple of leaks developed after our first year. Easy to fix. Painted frame after two years. Awning anchor vibrated lose. Replaced. Water inlet started leaking after a year. Easy to replace but keep an eye on it now under sink. Water heater drain leaked after one year. Added Teflon tape, fixed. Replaced bearings after one year. Just like a house maintenance must be done diligently. Every question you have will be answered on forum. If you are at all handy, most things are fixable. ENJOY!!!!!
TYSON PECK is offline   Reply With Quote
Old 09-06-2017, 09:18 AM   #13
Perth , Ontario
Thanks to everyone. This information has been very helpful.
Old 09-06-2017, 12:12 PM   #14
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
Trust your nose!
Good luck,
Peter
Absolutely great advice, Peter. The nose Knows. Any evidence of strange odor is definitely a danger sign. That also includes any trace that any type of air freshener has been used. Air fresheners are to cover up odors. If you don't have a sensitive nose get someone who does. I know my late wife could detect any off odor.
That being said I bought a 10 year old AS that had been well cared for, and stored in a building. It is stored in a building now. Nothing was evident when I inspected it, and none now.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Feeling comfortable buying a 9-year old AS? westcoastas Trailer Values 19 08-17-2014 07:36 AM
Model changes year to year for new buyer? Franswa 2005 and newer - Bambi all models 5 08-11-2014 06:13 AM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
Buying OLD trailer, wondering about axle, frame, and brakes NomadKitchen Axles 16 10-15-2009 10:52 PM
Engine/Year Trans/Year Matrix ViewRVs Mechanics Corner - Engines, Transmission & More... 36 10-23-2005 07:40 PM
