Old 12-22-2014, 12:47 PM   #1
Missoula , Montana
Blue Ox...Clamp on or bolt on?
I've pretty much decided to go with a Blue Ox hitch for our 19' Flying Cloud. Does anyone know for sure if I can use the clamp on or would I have to go with the bolt on model?
Thanks...
cajohnson is offline   Reply With Quote
Old 12-22-2014, 01:09 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
You can clamp the chain brackets to the trailer frame.
I watched this video and can not find anything in the explanation or visual evaluation that would in any way indicate there is a sway control. I can generally evaluate mechanical thing but this one claim is beyond me. The only claim I would agree with is the statement that the hitch is quite. unless the chain brackets have a "hand function" to them the drivers side will be a knuckle buster against the bottom of the propane bottles.
SwayPro By Blue Ox
If anyone can explain the sway control function please post
2004 Excursion 4x4
Old 12-22-2014, 01:23 PM   #3
HowieE's Avatar
Images: 12
Let me ask a question. Are the trunnion cups angled in towards the bottom. If that it would cause a additional force to be created on the inner bar during a turn or sway. Not sure I would like to rely on a SPRING as a damping function.
2004 Excursion 4x4
Old 12-22-2014, 01:50 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Thanks...
To actually answer your question the clamp on model is what is suggested by Blue Ox for Airstream frames. I contacted BlueOx prior to buying my BlueOx SwayPro and ask them. Afraid this thread will soon take off in many different unrelated directions like all WD threads tend to do. Good luck
MICHAEL
Old 12-22-2014, 01:59 PM   #5
Tincampers's Avatar
Sneedville , Tennessee
I've never busted a knuckle on my BO. Never had a bit of sway either. What amazes me is people who run down a product without any knowledge of how it works. Call BO and they will explain it to you.
Tincampers is offline   Reply With Quote
Old 12-22-2014, 03:23 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
SwayPro By Blue Ox
http://www.blueox.com/show-4-video.aspx
Can't explain it, but I would like to see one in person and tryout it out.
These videos of the SwayPro by Blue Ox are pretty good, especially the second one from the top, which talks about how leverage returns the trailer to center. It's not dependent on friction to stop sway. Interesting!
I think the any old trunnion type WD would have some of this same leverage effect, leverage returning the trailer to center, if the head is tilted slightly downward like it's supposed to be.
Alan
Old 12-22-2014, 03:35 PM   #7
Tincampers's Avatar
Come to Canopener, there will be at least 2 there.
Old 12-22-2014, 03:40 PM   #8
AWCHIEF's Avatar
Images: 33
I will be happy to have anyone take a look mine at Canopener. Spot 008.
MICHAEL
Old 12-22-2014, 04:38 PM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Mrpez and AWCHEIF
I appreciate the invite to take a look. I will not be at Canopener, so maybe another time.
Thanks!
Alan
Old 12-22-2014, 04:39 PM   #10
Tincampers's Avatar
I'm right across from you in 19.
Old 12-22-2014, 06:06 PM   #11
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Amen! This is my second BO and I have had no issues with 8K plus miles pulling 2- 25' AS's. The new one this year is better with no adjusting needed at the head, but I had no issues with earlier model either. That being said, I am sure someone will pipe in about why "they" think their hitch is better.
Old 12-22-2014, 06:17 PM   #12
Tincampers's Avatar
Let's hope not, for once I'd like to see a thread about hitches stay on topic. Plenty of other places to discuss those other ones....wink wink.
Old 12-22-2014, 06:18 PM   #13
Tincampers's Avatar
Originally Posted by A W Warn View Post
Mrpez and AWCHEIF
Thanks!
If you have any questions or would like some pictures, let me know.
Old 12-23-2014, 11:20 AM   #14
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Doesn't it work on exactly the same principle as the Equal-i-zer 4-point sway control hitch?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Propane Tank Bracket/Clamp Regulator Miked1256 Airstream Classifieds 0 09-01-2014 08:12 PM
hose clamp connection leaking mnboy1960 Waste Systems, Tanks & Totes 13 10-07-2013 06:29 AM
Propane tank clamp/bracket Dan S All Argosy Trailers 7 07-17-2010 11:47 AM
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 12 03-11-2010 07:08 PM
Awning Clamp Assembly airtime Awnings 4 10-03-2009 06:45 PM
