Old 10-05-2017, 01:06 PM   #1
2018 19' Flying Cloud
Coeur d Alene , Idaho
Bambi Heat Pump Question
Does anyone know if the "heat pump" on the 19' is a true heat pump or is it a heat strip? A couple of us are wondering if it would run on a Honda 2000i. If it's a true heat pump that requires spooling up the compressor then it would not (unless one has installed an EzStart system). If it's a heat strip and doesn't draw too much current it might work.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 10-05-2017, 02:20 PM   #2
2011 22' Sport
Portland , Oregon
My understanding is that the heat strip is only in the Sport, and that anything with ducted A/C is going to have a true heat pump.
SilverHouseDreams is offline   Reply With Quote
Old 10-05-2017, 04:52 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Turn on the heat, not the furnace. If the compressor starts up, it's a heat pump.
Old 10-05-2017, 04:55 PM   #4
2012 19' International
Southeastern MI , Michigan
It's a heat pump. It will stall the 2000. It even stalls my 3000 if another load is also running.
Countryboy59 is offline   Reply With Quote
Old 10-06-2017, 11:55 AM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Yup. It's a heat pump.
TB & Greg and Abbey Schnauzer
#3954
Old 10-06-2017, 12:55 PM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
It's compressor based. It actually pulls a bit more current in heat pump mode than in air conditioning mode. A generator that will "barely" run it as an air conditioner will stall out when you try it in heat pump mode.
Old 10-06-2017, 10:37 PM   #7
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Your 2000 will run the A/C and/or heat pump if you have installed a MicroAir EastStart 364. I highly recommend you go this route because the 364 also conditions the AC voltage and is much easier on your unit. If you are going to high altitude you may need a larger genny.
guskmg
Old 10-26-2017, 04:36 PM   #8
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Just got our 2018 22FB and the heat is an 11,000 btu heat strip and NOT a heat pump. It works great but have not tried it on my Honda 2000ui generator. Would only use the LP furnace if boon-docking. As mentioned, the ducted units are prolly a pump (reverse A/C).
M!ke
2018 Sport 22FB / Toyota 4Runner V6
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign NO5Y
Msherw is offline   Reply With Quote
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
