Old 11-13-2015, 07:35 AM   #1
2006 19' Safari SE
Hayes , Virginia
Balancing trailer
When we returned from last trip, I opened the door and cabinet on left had its door hanging from one hinge(no structural damage). In the past, I have found pillows, and about 5 rivet heads on floor and replaced rivets in various spots on ceiling. My tow/trailer, 2012 Tundra and 2006 19' Bambi-Safari, SE.
Carlisle tires at 65lbs, 15" (new)
Equal-izer hitch, trailer/truck level
Normal camping equip (nothing heavy)
60 mph plus/- a few.
I am taking trailer in for pressure test and floor rot inspection the end of this month to the dealer near Fredricksburg , Va on rt95. Before I tow another couple hundred miles, and replace door, can anyone see the obviously wrong setup? Thanks for any info. Tom
mocus is offline   Reply With Quote
Old 11-13-2015, 07:40 AM   #2
z , North Carolina
Hmm
Did they balance the tires when they installed them? That would be the very first thing to inspect IMHO. If they did, did you lose a weight? Do you see any places on the rims that are clean where a weight should be/was?
FishinHatteras is offline   Reply With Quote
Old 11-13-2015, 07:49 AM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Several tire shops have told me "we don't balance trailer tires". They will do it only if you insist. I always insist.
BambiTex is offline   Reply With Quote
Old 11-13-2015, 08:02 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It seems to me that 65 PSI might be a bit too much air for a Bambi.
A car of the same weight would probably run 35 or 40 no?
Brevi tempore!
Old 11-13-2015, 08:11 AM   #5
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
This one:
ST205/75R15 Carlisle Radial Trailer Tire LR D 2,150 lb Capacity
Calls for 65psi at a load rating of 2150 lbs.
Old 11-13-2015, 08:30 AM   #6
Mission , Texas
Wheel balance, bent rim, bad shocks ...
nrgtrakr is offline   Reply With Quote
Old 11-13-2015, 08:36 AM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We started with an Equal-I-Zer hitch on our 20 and moved it to our new 25. Pillows, cushions were getting tossed around so on Inland Andy's and Andrew Thomson's advice (both long time Airstream shops) we switched to a hitch with round tapered weight distribution bars. Nothing gets tossed around. She leaves a box of Kleenex on a side shelf and it does not fall off (with the exception of a couple of incredibly rough roadways). Our recliner chairs just sit in place during travel and never move.
Wheel balance is important, be sure the tires are not out of round. If that doesn't help you might take a look at flexibility of the w.d. bars.
Doug and Cheryl
Old 11-13-2015, 10:45 AM   #8
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
You might try Centramatics: Inland RV Center - The Nations Leading Expert in Airstream Innovations
We used to have all pillows on the floor and drawers open. Installed Centramatics and we're at 15,000 miles with almost No Problems.
The Ice Man is offline   Reply With Quote
Old 11-13-2015, 10:51 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Originally Posted by BambiTex View Post
This one:
Each....
Do the back two wheels of your trailer weigh 4,300 pounds?
Brevi tempore!
Old 11-13-2015, 07:33 PM   #10
2006 19' Safari SE
Hayes , Virginia
Originally Posted by J. Morgan View Post
Each....
Brevi tempore!
Only have the 2 tires. I think weight to be 4500. Tires call for 65 but will consider reducing if that could be problem. Thanks
Old 11-13-2015, 07:35 PM   #11
2006 19' Safari SE
Hayes , Virginia
Good suggestion, didn't think of that of a loss. Tires were balanced. Thank you
Old 11-13-2015, 07:37 PM   #12
2006 19' Safari SE
Hayes , Virginia
Me too also. Thanks
Old 11-13-2015, 07:43 PM   #13
2006 19' Safari SE
Hayes , Virginia
This one:
I knew I was doing it for some reason. Thanks for letting me see it again
Old 11-13-2015, 07:46 PM   #14
2006 19' Safari SE
Hayes , Virginia
This gal doesn't have 10000 on her but it is a possibility. Will check them. Thanks for suggestion
Wheel balancing beads nickcrowhurst Tires 27 06-07-2010 07:24 AM
Running Gear Balancing - Centramatic vs Balancing Beads Austin Runner Wheels, Hubs & Bearings 0 03-14-2004 10:42 AM
Tire balancing - one more time !!! femuse Tires 25 02-26-2003 06:04 PM
Wheel Assembly Balancing CJsTs Wheels, Hubs & Bearings 41 09-11-2002 07:55 PM
Wheel assembly balancing - which method?? 83Excella Wheels, Hubs & Bearings 0 03-23-2002 07:53 PM
