Old 11-13-2015, 07:59 PM   #15
2006 19' Safari SE
Hayes , Virginia
Originally Posted by dkottum View Post
We started with an Equal-I-Zer hitch on our 20 and moved it to our new 25. Pillows, cushions were getting tossed around so on Inland Andy's and Andrew Thomson's advice (both long time Airstream shops) we switched to a hitch with round tapered weight distribution bars. Nothing gets tossed around. She leaves a box of Kleenex on a side shelf and it does not fall off (with the exception of a couple of incredibly rough roadways). Our recliner chairs just sit in place during travel and never move.
Wheel balance is important, be sure the tires are not out of round. If that doesn't help you might take a look at flexibility of the w.d. bars.
Darn good suggestions......
If necessary, will do. However, it would have to wait until after my $$$$ trip to the dealer at the end of the month. Who knows, I my have to sell her to pay the bill. I know there is floor rot, but how much??? Recliners....my dream. Maybe someday. We do not anticipate any dry camping, and I had couch and water tank out last year to see how much room I would have. I thought I would check with the dealer re possibilities. Thanks
mocus is offline   Reply With Quote
Old 11-13-2015, 08:03 PM   #16
2006 19' Safari SE
Hayes , Virginia
Originally Posted by The Ice Man View Post
You might try Centramatics: Inland RV Center - The Nations Leading Expert in Airstream Innovations
We used to have all pillows on the floor and drawers open. Installed Centramatics and we're at 15,000 miles with almost No Problems.
I like Inland also. They do all of us some good. Thanks
Old 11-13-2015, 08:31 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You know it is vibration or violent movement.
Try putting a wireless camera inside to record... Or put your cell phone in a strategic location then Drive around.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 11-13-2015, 10:19 PM   #18
2002 19' Bambi
Lafayette , California
If our 2002 19' Bambi is any guide, 65lbs. pressure in the tires is normal and was recommended for our trailer by Airstream. Because of load carrying capacity with a single axle trailer, reducing that is probably a bad idea.
We have used Centramatics with balanced tires for many years and our Hensley hitch has tapered bars. Despite all, our California roads can sometimes shake things around. Drawers and doors stay closed, but the hinges of the cabinet door to the left of the entry door would eventually loosen up. I solved that this last year by putting plastic bumpers on the inside of the door so that they rested on the shelves when the door was closed. Works great.
We do have a small vacuum which likes to wander around, but then it is sort of precariously perched. After having driven for a while, it commonly greets us when we open the Airstream's door. It does not harm, so we haven't bothered to tie it down.
Tim
Tim A. is offline   Reply With Quote
Old 11-13-2015, 11:19 PM   #19
Cardinal283's Avatar
Dallas , Texas
Mocus, the tires do not call for 65. What is printed on the tire is simply the maximum pressure that tire can handle. You need to determine the weight of your trailer and find a tire chart for your tires to determine the proper inflation. Think of it this way... Carlisle makes the tire but has no idea what the final application is going to be. It's up to the vehicle manufacturer (or in this case you) to determine proper inflation based on load. At 65 PSI per tire that's 4200lbs of load those tire can carry. That's almost what my 26' Overlander weighs with 2 axles to carry the weight. Obviously check the balance, but based on the current information I would try adjusting the tire pressure based on the weight of your trailer.
Cardinal283 is offline   Reply With Quote
Old 11-14-2015, 12:08 PM   #20
2002 19' Bambi
The GVWR of our 2002 19' Safari Bambi is 4500 pounds. I think it should be clear why Airstream recommends a tire pressure of 65 psi for these single axle trailers.
Tim
Old 11-14-2015, 08:15 PM   #21
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Please, take time to scan this website...
RV Tire Safety
Channing
WBCCI# 30676
Old 11-17-2015, 02:15 PM   #22
Dallas , Texas
Wow. I had no idea the newer trailers were so heavy.
Wheel balancing beads nickcrowhurst Tires 27 06-07-2010 07:24 AM
Running Gear Balancing - Centramatic vs Balancing Beads Austin Runner Wheels, Hubs & Bearings 0 03-14-2004 10:42 AM
Tire balancing - one more time !!! femuse Tires 25 02-26-2003 06:04 PM
Wheel Assembly Balancing CJsTs Wheels, Hubs & Bearings 41 09-11-2002 07:55 PM
Wheel assembly balancing - which method?? 83Excella Wheels, Hubs & Bearings 0 03-23-2002 07:53 PM
