Old 11-10-2018, 09:13 AM   #1
Pearl , Alaska
Atwood heater plug socket size ?
Thanks for any info...
Deltaboy59 is offline   Reply With Quote
Old 11-10-2018, 09:45 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Either 7/8” or 15/16”. Special offset wrench available.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 11-10-2018, 10:08 AM   #3
Pearl , Alaska
Thank u much
Winterizing has begun...
Old 11-10-2018, 12:43 PM   #4
Long Island , New York
Mine is 15/16" and a 6" extension lets the socket get the plug, with the ratchet wrench clear of piping etc.. If you carry a full set of 1/2" drive sockets up to 1" +/-, and a breaker bar, you will also be covered for most lug nuts on the tow vehicle and trailer.
Old 11-20-2018, 05:34 AM   #5
JJTX's Avatar
2018 19' Flying Cloud
South of Austin , Texas
A crescent wrench will break it loose.
This plastic plug should not be super tight. If it drips, a little tape will stop it.
2018 Bambi 19
JJTX is offline   Reply With Quote
Old 11-20-2018, 05:58 AM   #6
. . . and round off the corners of the plastic nut, thus making it unusable by the correct socket and extension. Vice grips work too — once or twice.
Another thread with more details:
http://www.airforums.com/forums/f163...on-189503.html
Size of socket for lugs Van1 2009-2015 Flying Cloud 18 11-21-2014 10:36 PM
Bambi's Socket is Too Tight for my Oversized Plug! Airrogant Electrical - Systems, Generators, Batteries & Solar 6 05-23-2014 09:40 AM
Lug socket size mysecondjoy Wheels, Hubs & Bearings 3 04-11-2011 09:04 PM
replacement plug socket- 1975 airstream robertel Electrical - Systems, Generators, Batteries & Solar 4 09-09-2010 02:58 PM
spindle nut socket size Ruben J Axles 4 04-20-2009 10:12 AM
