Old 03-18-2015, 03:51 PM   #43
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Finally got a good look at a Lance the other day. Reminds me of a Clorex bottle inside and out, little to no positive personality. I will say they do look very well made and the owner was very happy with his purchase.
MICHAEL
Old 08-11-2016, 05:07 PM   #44
nixpix
2015 20' Flying Cloud
Jackson , Wyoming
Not an easy decision
I wonder if the questioner finally decided whether to go with an Airstream or a Lance. I have owned 5 Airstreams over the past decade or so and am about to give up on the brand. I have an unusual program in that I spend a lot of time on gravel roads and always dry camp. The Airstream is just not up to the task. It leaks way too much dust, the ground clearance is marginal and the interior construction gradually falls apart. Also the plumbing system has many points of failure and is extremely difficult to service when it does fail.
Whether any American made travel trailer is truly up to the task is an open question. I suspect that only Australian travel trailers are built to withstand the rigors of my style of travel. There is always the EarthRoamer, but it is far to large for me.
It's a pity that Airstream doesn't build a version of the Sport, say, that had better ground clearance, better insulation and a simpler more durable build out.
nixpix is offline   Reply With Quote
Old 08-11-2016, 05:27 PM   #45
Airstreamer In Training
FCStreamer's Avatar
2014 30' Flying Cloud
Originally Posted by eeltinge View Post
Greetings, Everyone! I am a new member and this is my very first posting. I own a 2014 Toyota 4Runner that can tow 5,000 lbs. max. I want to buy a new Airstream 22-foot Sport or a Lance 23-foot 1985. Both have a dry weight around 3,800 lbs. The Airstream is about $15,000 more expensive. Any recommendations? Thank you.
I'd recommend the Lance.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2013 Cadillac Escalade Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 02-01-2017, 07:26 PM   #46
2017 22' Sport
Salisbury , Maryland
Images: 8
The 1985 has a walk around bed. Not the best use of space. The frontal area is greater and will hold a lot more wind. Weight is not the only factor. 1685 is still on the heavy side for 5000 towing. AS Bambi 22 is 7' wide will tow easier but the less then 2' walkway inside is tight. If you are going use it for travel get the 22 Bambi. If you are going to stay in it for long periods, get the Lance 1685 if you can find one.
Thonevan is offline   Reply With Quote
Wow, we did have this on the Lance Forum! :-) Cyberous Friends of Dorothy 5 01-27-2013 08:20 PM
Lance Armstream??? tphan Off Topic Forum 1 08-07-2005 11:28 AM
Go Lance - 7 !!!! swebster Off Topic Forum 11 07-25-2005 03:48 AM
