Old 08-03-2011, 08:09 PM   #1
2008 19' Bambi
Decatur , Alabama
Air Conditioner drip
My air conditioner is dripping water on the floor! I took the filter out and put my finger up over the lip and the cover was full of water. Why is this not draining?
All help would be welcome.
Thank you
Steve
sarmstrong@allsportinc.com
Nightwind15 is offline   Reply With Quote
Old 08-03-2011, 08:21 PM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Probably because your drain tube outside is plugged up. Go outside to the streetside of your rig and see if you see water dripping. If not, locate the drain tube and stick piece of coat hanger up the tube and free the blockage. Could be algae or a mud dauber wasp blocking it.
hope this helps.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 08-03-2011, 08:30 PM   #3
tpi
Trabuco Canyon , California
I carry a small piece of plastic tubing which fits in the drain hose in wheel well. I can blow in it and confirm the drain is open.
Otherwise be sure your trailer is level, not tipped away from the drain tube side. Don't operate the AC extensively with doors/windows open in humid conditions. Even normal operating AC can drip under these circumstances.
tpi is offline   Reply With Quote
Old 08-04-2011, 08:20 AM   #4
2008 19' Bambi
Decatur , Alabama
Thank you
Going out now to see if I can locate the drain hose! Small plastic hose in hand to try your trick! Thank you
Stephen
Old 08-04-2011, 08:31 AM   #5
2008 19' Bambi
Decatur , Alabama
Ok, I know this is likely stupid but I cannot find the drain hose. Can someone give some references where it comes out.
Thanks!
Old 08-04-2011, 09:52 AM   #6
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Mine has done this from time to time. Now as a preventative measure, when I am heading on the rare trip (we generally camp in wooded SPs with no hookups) where I will use AC, I blow some air at moderate pressure (20-30 lbs.) up the tube and it keeps things freed up. On my trailer it seems that you can't get to the drip pan drain (where I think it gets clogged) very well from up on the roof, the condenser is (understandably) in the way. Guess I am stuck with using air pressure, vs actually cleaning out the pan.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 08-04-2011, 10:58 AM   #7
2008 19' Bambi
Decatur , Alabama
Found it
Under the wheel well!!
Old 08-04-2011, 02:58 PM   #8
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
You can't really clean out the pan, but you can get to where the drip tube attaches to the pan on some ACs by just removing the filter on the road side and on all by removing the inside shroud.
On my former 22 International, some ham handed Airstream assembler cracked the fitting where it entered the drip pan while jamming the drip tube on the fitting. It is a major job to replace the pan, but I was able to use "Marine Goop" to make a repair that held quite well.
John W. Irwin
WBCCI #9632
Old 08-04-2011, 03:04 PM   #9
Pahaska's Avatar
Hays County , Texas
My solution to clogged drip tubes
I do some paint spraying. I noticed that the filters that slip on the suction tube in my spray gun tank could be used to keep bugs out of the AC drip tube. I used two of the plastic paint gun filters, one for the AC drip tube and one for the refrigerator drip tube. I had to use a knife to open up the holes in the top of the filters a bit to slip on to the rubber drip tubes without crimping them closed. About once every two years, I remove the filters and flush out accumulated dirt. I have never had a clog since using the filters.
I bought my filters at Sears in the tool area. HD, Lowes, or any place that sells paint guns may stock the filters.
John W. Irwin
WBCCI #9632
Old 08-04-2011, 03:31 PM   #10
I use a straightened coat hanger to remove mud dauber and other stuff once a year. They always seemed to find a way to build a nest during the fall and early spring before the AC is used full time.
I run the coathanger up into the drip hose from the bottom of the banana wrap on mine. It's amazing what comes out sometimes.
Nests can restrict consistent flow on drip lines
0557 is offline   Reply With Quote
Old 08-04-2011, 03:35 PM   #11
Pahaska's Avatar
Hays County , Texas
Before I put on the filters, I used a length of 1/8" steel cable to run up the tubes. It is nice and flexible and the cut ends chop away any crud.
John W. Irwin
WBCCI #9632
Old 08-05-2011, 07:31 AM   #12
2008 19' Bambi
Decatur , Alabama
Thanks for all the great ideas!`
I am going to Lowes to get the paint filters today. Now I am dripless again!
Old 07-31-2012, 02:36 PM   #13
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
We don't have a bambi but we do have a 2005 model. It has a penguin ac unit. It is dripping water from the fitting where the condensate line attaches. The plastic fitting screws into the condensate pan. Like another post, there was caulk on the fitting and I presumed the PO or a repair shop had patched the leak and now the patch was failing. But based on the attached pictures of the drain pan available from Out of Doors Mart, it appears that there was always caulk applied to seal that fitting both inside and out. From what I can tell you cannot get to the inside without removing the ac unit. Is this correct? So far my additional patches have not been successful. I feel like I have to get at it from the inside.
Not sure if I uploaded these pics correctly. I hope you can see them.
ID:	164305   Click image for larger version
BeachHouse is offline   Reply With Quote
Old 07-31-2012, 02:43 PM   #14
Pahaska's Avatar
Hays County , Texas
Mine initially leaked on my 2003 International 22. The spout on the pan was fractured during assembly at Airstream. I successfully used Marine Gunk to seal it by reaching up through where the filter mounts and applying the Gunk all around the fitting with a tongue depressor. I just pressed gobs of Gunk into place.
John W. Irwin
WBCCI #9632
2006 bambi
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
need air conditioner ally 1966 Overlander 2 07-02-2011 09:54 PM
Air conditioner went south... Bing-Bing Furnaces, Heaters, Fireplaces & Air Conditioning 12 06-16-2011 06:14 PM
Old air conditioner removed... Steps for new installation Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-14-2011 03:25 AM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
